#15 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
I think it will be a flow restriction over the Big Gulp design at WOT. It does look like it might have an advantage at lower RPM's for IAT's. But at full tilt on ZL1's pushing the blower (800+ HP), I suspect a drop in flow vs RFBG and less peak HP.
GM Gen V Calibrator
#16 |
Moderator
Funny you mention that… I was actually debating not using the air filter shroud at all for that reason. I’m thinking take advantage of the better tube and much bigger air filter over the RFBG, and that’s it.
#17 |
![]() Drives: 19’ ZL1 A10 / 16’ C7Z M7 Join Date: Apr 2021
The metal heat shield of the RotoFab doesn’t affect anything IMO. Not even a metal tube when actually driving the car down the road. The custom 5” I had made for my setup is the only CAI I have ran on any vehicle that actually matches the air intake temp with ambient temp.
#18 | |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#19 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#20 | ||
#21 | |
#22 |
Petro-sexual
That's a B@D@$$ intake! Was it a PITA to tune with the 112?
#23 |
Moderator
I suspect the much larger filter on the JLT is going to pay dividends vs the RFBG filter… the surface area of the JLT element is much bigger.
#24 |
#25 |
Moderator
No surprise since the MAF sample tube diameter was unchanged vs the BG.
#26 | |
Snackbar Tuning
I'd love to see the dyno hood opened vs hood closed on the JLT design.
GM Gen V Calibrator
#27 | |
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
#28 | |
Moderator
