#15 | ||
Honestly the cam that is in your setup now isn't bad for a 390. The Katech cam will idle even smoother and be stealthier. It only has 3.5 degrees of overlap.
#16 |
I've looked for a cam with a little more overlap than my current 5.5, but haven't found one. LME jumped from 5.5 to 24 degrees due to the new heads, but it's somewhere in between, like 12-14 degrees. LME and probably KaTech will grind it anyway I want.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 07-17-2025 at 09:48 AM. |
#17 | |
236/252 Duration @ .050'' 120 LSA, 116 ICL (120+4) .648''/.639'' Lift with 1.8 rockers Which has 12 degrees overlap, which is a compromise, but I don't know if a cam is worth extra $$$$.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#18 |
![]() Drives: 2018 Camaro ZL1 A10 Join Date: Feb 2022
This cam has only 4 degrees overlap
#19 |
Another example of my failing memory.
2020 ZL1LE A10.
#20 |
Examining these CID LT4 flow numbers, it is evident that more lift is better. I don't know how much piston clearance I have now.
2020 ZL1LE A10.
#21 |
Heads arrived so we'll start putting it back together next week
2020 ZL1LE A10.
#22 |
Petro-sexual
GD - THOSE ARE PURDY!!!
#23 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
That's exactly what I was thinking. Nothing prettier than a freshly-CNC'd piece of aluminum!
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#24 |
She's coming back together. CID heads, Eddie, and the new intercooler tank are done. Ordered longer pushrods, headers next week, need 12 gal. of Stay Frosty, and going to take a good look at the rear main seal area to see if I can avoid a 13-hour shop charge.
2020 ZL1LE A10.
#25 |
fo'shizZL1
Lookin' good! Nice to see it coming together. Good luck with the rear main!
#26 |
We're doing fluids tomorrow and will crank it up, drive it around, scan it, see if everything's working, such as the WB. See if the intercooler system has any leaks, etc. I'm not going to dyno it now, but rather we'll road tune it and dyno later. I decided to do the rear seal sometime during the winter.
The only new stuff are the heads, push rods, plugs, injectors, and intercooler tank
2020 ZL1LE A10.
#27 |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
radz28 is right... Those heads look amazing! Great job on your build and good luck on your first test !
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#28 |
We've got the car back together and tuning is underway. But let's talk a little bit about this rear seal. We've taken a close look at it and there is a little bit of moisture on it, and it looks like there was one drop of oil that was about to drop. But my questions are, when did GM change to such a flimsy LT4 rear? The front seal is much firmer and of course as is the LS rear seal.
I have spoken with LME about the clearances in this engine being greater than stock clearances. I'm assuming that that contributes to additional pressure on the rear seal? I assume that if a ring was hurt, it's highly probable that it will blow out a new seal
2020 ZL1LE A10.
