Old 05-16-2025, 08:58 PM   #15
Xelor
Drives: 2022 ZL1
Drop the 15K and Modify the SS
Xelor is offline   Reply With Quote
Old 05-16-2025, 09:45 PM   #16
I started modding the car less than 5 months and 2000 miles on the clock into ownership.
To some degree I felt I had to because of GM's 8L90 fluid and tune shenanigan, but then I thought why not add some power, too
Old 05-17-2025, 06:27 AM   #17
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
If you’re worried about warranty then get the ZL1. I’m fairly certain the LT1 uses the same crank, pistons, rods, bearings, etc as the L87. The only reason it’s not part of the recall is because Chevy didn’t make enough Camaros to cause a stir about them blowing up too but from what I’ve seen post covid LT1’s aren’t fairing too well.
2012 Shelby GT500 with VMP Gen 3R.
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 05-17-2025, 10:16 AM   #18
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Originally Posted by White1SS View Post
I do like the look of the 17-18 models, and thought they might be a bit less costly than newer 19+ models, but I'm certainly not tied to those years.
You might be able to keep the rear end look of a '17-18 with a 19+ model - see this thread on my LT de-fresh for more info:
Switch '19+ front/rear fascias to '16-18 style
Old 05-17-2025, 10:57 AM   #19
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
You have no idea of the amount of sleep I would lose voiding a perfectly good warranty...lol.
On the other hand, I'm getting older and want to experience the full joy of a truly fast car while I still have the ability and nerve to do so.
Ha! Well, I should have added, technically all my mods are bolt on ! So, if needed (I'd never do so) I could always go back to stock I guess.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 05-18-2025, 04:21 PM   #20
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
You might want to consider a newer ('20+) ZL1 and leave it completely stock. Tinker with your 496 Olds and when it causes a bit of frustration you have a nice 650 HP car to go drive for a nerve calming therapy session. I haven't modded my '15 Z/28 and I have used it in plenty of situations when my Olds has decided to throw a mechanical temper tantrum.
ariZona28 is offline   Reply With Quote
