#15 | |
Also note that the alternator on our car charges rather conservatively, it takes very long to get back to full charge, a short drive doesn't do much. If you want to find out about the battery's health, use a tester, here's an excellent, versatile, Project Farm approved one: https://www.amazon.com/dp/B07Z67MMGC
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle Terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 05-30-2025 at 07:25 AM. Reason: typo |
#16 | |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#17 | ||
Thank you Al Oppenheiser!
In a completely full battery (mine right now, for example) it will move through all the yellow lights in about 30 minutes to a couple hours tops. Then it spends a week at 1st green light before finally getting to 2nd green light. After a jump, mine took about 3-4 days to completely charge up the dead battery. Quote:
And yes our cars are almost deficient to the point of defective at charging up the AGM after a jump. A 2 hour long top down daytime cruise was not enough for my Z. And this will very much falsely convince you to think your battery is dying/dead and in need of replacement, when it doesn't... if you do not know otherwise. Learned my lesson the hard way before I got the CTEK. YMMV
#18 | |
#19 |
Coupe Newbie
Drives: '23 CT5-V BW, '21 Corvette HTC Join Date: Jul 2011
I just experienced a defective OEM battery with my ’23 Blackwing.
The car sat for 12 days. I opened the trunk with the key fob, but the trunk wouldn’t latch. I hit the key fob again to unlock the car — it was completely dead. I had to pop the cover off the door handle to access the mechanical lock to get into the car. I was unsuccessful in getting the car started using my low-amp Battery Tender Plus and a low amp CTEK charger, even after several days connected directly to the battery with the negative lead disconnected. I ended up purchasing a NOCO 10-amp charger (https://www.amazon.com/dp/B07W3QT226...fed_asin_title). After approximately 6 hours of charging, I was finally able to start the car. I took it to the Cadillac dealer, and their 2-hour battery test confirmed a bad cell. I received a new replacement battery under warranty. We’ll see how long this one lasts.
