#15 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
The issue was caused by the wrong viscosity on the OEM transmission fluid used.
#16 |
This thread includes info from GM management on what to expect from this problem-- basically flush ASAP and hope for the best, otherwise you need a new TC.
Also, some info on the fluid chemistry. The fluid is hygroscopic. The retained water causes burnishing of the TC clutch. https://bobistheoilguy.com/forums/th...issues.303084/ |
#17 | |
![]() The potential silver lining, though, is that if the service manager is an upstanding person, he should give you a new TC free of charge, and then you won't need to pay for a tune, you can just make sure they use the correct (Mobil1 Synthetic LV) fluid and the trans should be fine going forward.
#18 | |
![]() ![]() ![]() Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
