#15 | |
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock |
#16 |
Will do!
#17 | |
Thanks KingLT1! Have you picked out what tires and sizes you will run with these?
#18 |
285/35/20 555g2 front, 305/35/30 555r2 rear. I am currently running 245/40/20 555g2 front and 305/35/20 555r2 rear. I want a more aggressive offset, and the wider 10.5 wheel will utilize the 305 better than the stock 9.5. TBH, I have owned the car for almost 8yrs and I just want to change the look up a little more than anything.
#19 | |
305/35 on a 9.5 wheel...Nitto has been known to run small but has that changed recently to your knowledge? I could be wrong but I thought I read they are making them bigger now?
Tis the season to have obsessive compulsive disorder about the car so I understand wanting to change stuff I'm looking at changing my wheels too. I was talking with KRNC as well. As far as his wheels go, I'm torn between the Scelus wheels you posted and the Storm Rally Spec (lightweight) I was also weighing out the idea of dropping to a 19" wheel but not sure if I should do that. Just curious, what was your thinking going to the 10.5 vs 11" rear wheel? Just for comparison, these are the Storm Rally Spec (lightweight) I would probably go gloss black with my car though. Quote:
#20 |
10.5 is lighter and will fit up to a 315. So I didn't see a point in going 11". Yes Nitto runs a little narrower. The 305/35 works on the 9.5 but it bulges a little. No issues other than it doesn't use all the tread pattern.
#21 |
Got the wheels today. Look great...packaging was exceptional. I weighed both front and rear in the plastic bag, cloth cover, and foam rings. They came up around 27lbs. So 4-5lbs heavier than advertised but still pretty decent imo.
#22 |
Those look awesome! Thank you for posting King! Will you have them on the car anytime soon? Or are you waiting till spring?
#23 |
No problem!!
If we get a nice day, I might take it over to the shop and put them on.
#24 |
Does anyone know if 285/35/20 will clear the front struts with a +25 offset? I am deciding between 275/35 or 285/35. Tire fitment wizard shows .5" closer to the strut. I read others in the past stating 285/35 worked on Non_MRC (which mine is) but they were using a +23 offset MRR wheel. Also, Nittos tend to run on the small side, so I think I am good, but wouldn't mind a confirmation. Lol
#25 |
Went with 275/35/20 for front. Have tires mounted and balanced. Might try to bolt them up this weekend.
#26 |
Had a little extra time today after work so I installed the wheels. Didn't take it outside since it's wet/icy and nasty out.
#27 |
![]() Drives: 2019 Chevrolet Camaro 2SS A10 Join Date: Jul 2019
Looking good my man
2019 Camaro 2SS A10 Procharged, Flexfuel, with Stainless Works headers back to Legend series mufflers.
#28 |
![]() Drives: LT1 Join Date: Apr 2024
Looks great!
