#15 |
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
Mine stays plugged in 24/7 but I also disconnect battery when parked. Car is weekend warrior that stays in storage. I figure keeping it in V8 will at least help. It’s been plugged in 7k miles. Works good. This is temporary until I figure out what I’m doing with this car so I can get it tuned. Having a difficult time deciding on mods lol
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
#16 |
![]() Drives: 2024 2SS vert w/M6 & Dual Mode. Red Join Date: May 2023
Manual equipped cars do not have AFM.
#17 |
![]() ![]() ![]() ![]() ![]() Drives: '23 1SS Sharkskin A10 Join Date: Sep 2018
#18 |
They have the same AFM lifter hardware. These lifters never activate on M6 cars, but they are the same failure prone parts, and yes, it's possible for them to fail even with 0 activations.
#19 |
![]() ![]() ![]() Drives: People crazy with my sexiness Join Date: Jun 2023
The only true way to eliminate any risk of lifter failure is to physically remove the AFM actuators, and replace the cam an all the lifters with a non-AFM kit. If you can do it yourself it’s less than $2k but to have a shop do it it might run you $5k. I’m seriously considering doing it because I don’t ever plan on ever getting rid of my Camaro….. last year of any V8 coupe with a real manual transmission, at least from GM.
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023 2024 2SS 6MT coupe Sharkskin/Light gray Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers Gray painted split spoke wheels Illuminated footwells/illuminated bowtie |
#20 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
When GM changed the recommended lt1 oil from 5w-30 to 0w-40 does anyone think afm problems had anything to do with that?
#21 |
![]() ![]() ![]() Drives: 24 LT1 M Join Date: Oct 2015
Probably the issue is people doing 10k oil changes.
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30 |
#22 |
Absolutely not IMO
#23 |
#24 |
![]() Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
Yep. I still find it shocking that people would go this long between oil changes. I don't care what brand of oil or what your oil analysis says, it's crazy. The manufacturer's only changed to these extended intervals for two reasons: EPA mandates, and to create the illusion of "cheaper" maintenance for the owner. I'll never go more than 5K on an oil change, oil is pretty cheap compared to engine work.
ΜΟΛΩΝ ΛΑΒΕ
#25 |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
I'm the opposite.. I could probably extend my ~3100 Mile oil change interval. It's just easy to keep track of to just do it at the 5000KM mark on the odometer (I do with all my vehicles, even my shitty Ford Ranger).
