Old 10-06-2024, 04:02 PM   #15
Colin101234
Colin101234's Avatar
Drives: 2017 FIFTY 2SS HCI
Your top end looks like it would be on the noisy side based on the components chosen. You are running a high lift cam that likely has moderately aggressive lobe rate combined with a spring rated for .700 lift. That is snapping the valves open and closed aggressively and you are hearing the valve noise being amplified through the headers. Some headers are worse than others depending how thick they are.
Also note that with aluminum engines you are going to get .012-.013 expansion when the engine comes up to temp. So, make sure you account for that in your preload target.
That being said I believe BTR recommends .050-.100 range for preload on these lifters, so they are very forgiving which is why I posted what I did above. I don't believe you have a preload issue.
When you say you get a .012-.013 expansion from heat. Does that mean I get less preload or more preload with hot temps?
*STG 1.5 Frankenstein ported/milled heads(.025),
*Custom Cam Motion Cam (224,242[.647/.639])
1 7/8 headers, Ported LT 2 Manifold, Solar Ported 95mm TB, Cold Air Induction CAI, CHE Valve seats, Inconel EX valves, FED/PAC .700 dual springs, VVT Delete, CHE Trunnions, Caddy R Lifters, 3 In Midpipe, NPP Borla atak mufflers, GPI tune.
Colin101234 is offline   Reply With Quote
Old 10-06-2024, 04:05 PM   #16
Colin101234
When you said you Get an avg. of .012-.013 heat expansion. Does that mean you get more preload or less preload at hot temps?
Old 10-06-2024, 04:12 PM   #17
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
Typically it is going to mean you lose preload. But to be honest 0.065" is a perfect cold preload if you are sure that is where you are at. Your valvetrain is probably just noisy like mine.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 10-07-2024, 09:22 AM   #18
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You lose preload from expansion, but you would still be in the low 50's so it's more than likely just a noisy drivetrain due to parts selection. If you want quiet, move down to a lower lift <.600 smoother lobe cam that works with beehive springs.
Old 02-16-2025, 08:10 PM   #19
Colin101234
I don't mind the noise, and I no longer over think it as it is really not bad. However the car has been in winter storage and I have noticed when the car sits for more then a couple days without being started the lifters bleed down and are SUPER noisy for around 5 minutes and then start to significantly quite down over the period of another 5 minutes. I assume this is from whatever lifter the cam lobe ends up stopping on when I shut it off forces it to bleed down completely.
