#15 |
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I need to follow up with this thread and give it the update that it needs for anyone looking to do a Katech module.
The JMS booster is indeed THE issue causing my P2635 code. What I didn't notice at the time in the slough of old permanent codes I had stored due to a previous project I was working on in the fuel system was that I had a U042B chassis control module communication failure that has been pending and was the tell that it was the JMS causing my issue. The moment I eliminated the JMS from the circuit and set it all back to OE connections the codes went away and the fuel system is happy as it once was. The problem is that the JMS is meant for a single channel fuel pump, and while this is indeed a single channel technically speaking, the Katech Vaporworx controller is connected to the battery and has no way of boosting voltage that the JMS does prior to any boosting at all. I realized it when I hooked up my voltmeter to the JMS and saw that resting static voltage with the car off I was looking at 14.4 volts before doing anything at all. It makes sense now because battery voltage depending what sort of battery you run is going to be anywhere from 12.6- 13.3 volts at rest. So the moment you turn on the car there is a voltage conflict between the two pumps, chassis control communication failure code, and fuel pump insufficient flow code because they are both flowing differing amounts right out of the gate. Happy modding guys, I'm glad this has been resolved. Fuel system looks great once again!
758 HP/ 804 TQ |
#16 | |
![]() Drives: Z06 Join Date: Oct 2021
I know alot of you guys running e have been using this for a loooong time with good results |
#17 | |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
When I did my X-Port and 2.3 upper, the boost increased so much, I had to start dropping E and eventually it was E5 (almost none). That's when I went with the Katech Dual Fuel pump and Port Injection: Dyno base line with E5 was 650rwhp and 534rwtq. Link below is my build, and specifically my JMS mod starts at post # 215 https://www.camaro6.com/forums/showthread.php?t=611982
Katech Track Day CAM 38%•BTR Dual Valve Springs-Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Ported Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper & ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI Interchiller Stage 2•THPSI Port w/875cc Inj•Dual Drop In Fuel Pump•DSX Aux Pump•Stainless Works 2" w/Legend NPP Axle Back•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout/Bushings Kit•DSS Chromoly DS•RPM 8-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
#18 | |
Far as compatibility issues with the JMS. Ran into a similar issue trying to use the JMS combined with a SMG big boy pump. So evidently the JMS must only work with stock pumps because I have tuned a couple cars using a JMS with LT4 pump combined with DSX aux pump and no issues.
#19 |
Super Stock
*sigh* I guess the nightmare project continues... After removing my JMS I took the car out for a drive to go do an errand a few towns away. Went to give the car some throttle over 40% and got stopped up into reduced power/ limp mode. Good thing I had my laptop and scanner with me because I was able to clear it out, but before I did I got a code P2138 Accelerator Pedal Position (APP) Sensors 1-2 Not Plausible, along with a C0242, U0401, and U042B.
After clearing I kept driving and all looked okay. I tried hitting the accelerator again. Same thing. Once I got home and came to test it I tested the TPS on the throttle body. Was able to get 83.9% full open no problem. When I hit the pedal I can't go above either 42.4 or 44% and then at full close the TPS reading goes down to 23%. Doesn't seem normal at all and it almost seems like my accelerator pedal suddenly failed. Just seems weird that I disconnect my JMS and suddenly I'm getting all these dumb issues. Are pedal failures common on these? I have searched and don't see a lot, but it was also like 2 am and wasn't in the right state of mind to look into this. Dealer wants some $500-$600 for a pedal assembly which is absolutely insane.
758 HP/ 804 TQ |
#20 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Any chance you pulled something loose in the wiring harness at the pedal when you removed the JMS harness?
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#21 |
See you at the Track!
Drives: 2022 Rapid Blue SS 1LE Join Date: Feb 2022
This was my thought as well. If the JMS was wired into the accelerator pedal, then maybe the wire was cut (Fully or partially) while removing it. Especially if a wire tap was used to install it. I have seen those cause so many wiring problems.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD) |
#22 | ||
Super Stock
I've got a Soler throttle body and though it tested out okay on HPT, Katech suggested trying my OEM original to rule it out. I just can't understand how a throttle body would suddenly go bad from one moment to the next though. Same with the accelerator pedal.
758 HP/ 804 TQ |
#23 |
Any change that a PIN in the wiring harness has been affected possible a PIN misalignment or anything as such? I agree to try the stock TB, but that would not make any sense. If you need to try another Soler, I have 100mm collecting dust, I could ship it to you for testing. PM me if you are interested in a loaner for testing!
#24 | |
Super Stock
Just weird because prior to even touching the pedal's wiring whatsoever everything was totally fine. Then all of a sudden the car is going haywire the moment the JMS gets disconnected, not even related to anything throttle body and accelerator pedal related.
758 HP/ 804 TQ |
#25 |
You had to splice your wire and intercept it at the FPCM right? Is there a change that connection is not solid and needs "redone" ?
#26 | |
Super Stock
I spoke with Mike at Soler and he said the code is typically not related to the throttle body, but obviously do not discount it out of possibilities. He suggested first disconnecting the battery and leaving it disconnected for 5- 10 minutes so it would totally clear any keep alive values retained within the PCM. It would make sense that after removing the technically "load" out of the circuit that you may need to do a full clear out to reset all learned and retained values to zero. It was something I thought of but didn't necessarily see the need in doing, though looking back at it all it should have been one of the first things I did before chasing possible ghosts in the setup. If not, he suggested logging APP 1 and 2 parameters and seeing how they behave in HPTuners as the pedal is swept through. If the values do not go up and down respectively independent on both channels as a constant value then the pedal is indeed defective and this was all just a freak accident/ defect occurrence and will need replacing.
758 HP/ 804 TQ |
#27 | |
![]() Drives: Chevrolet Camaro Join Date: Apr 2022
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
#28 | |
fo'shizZL1
![]() Just kidding.But seriously, is there some whiz bang aftermarket pedal that adds 200hp or modifies the stock pedal progression or something? I didn't know there were pedal replacement options out there.
