#15 |
You should check out the Banks PedalMonster controller. Seems like a better product.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions |
#16 |
![]() Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
SOLER | PERFORMANCE is hands down better and the Customer service is second to none!
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake |
#17 | |
PedalMonster is the world's only OBD-connected throttle sensitivity controller. This real-time vehicle data is used to provide a smooth pedal response, Low-Speed Trim (traction control), and patented speed and gear-related features like Reverse Safety. Why it's better PedalMonster is the only throttle controller connected to the vehicles Onboard Diagnostics (OBD) port.
https://bankspower.com/collections/throttle-controllers
#18 | |
DARK KNIGHT
#19 |
Yup. That has how it knows what speed you are at, what gear you are in and what transmission you have. It also knows if you are in reverse and reverts to stock settings. Soler knows none of those things as it not connected to the OBD port.
#20 | |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
Disables the throttle controller when vehicle is placed in reverse. Reduces the effect of the throttle controller at speeds under 10mph. |
#21 |
BLUPRINT_1LE
Drives: 2022 Rapid Blue SS 1LE Join Date: May 2017
Great quality product! I enjoy mines! Definitely wanted a different look over the other aftermarket throttle bodie that’s commonly used!
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE YT: BLUPRINT_1LE ---------------------------------------------------------------- |
