Old 08-27-2024, 04:56 PM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by Megahurtz View Post
In ZL1's and Z06's the CCM only adds control of the active exhaust. The fuel pump settings are included in the ECU so you can edit the fuel pump settings with only licensing the ECU(which I assume is telling the FPCM what to do). There may be some odd ball years out there where this isn't the case, but at least for any 2017+ that is how it works now. Pretty sure all of the C7's/Z06's work this way too back to 2015. 2014 might be a weird year. I think maybe that's why I was confused here?
Yep that is what I have experienced as well. The other 2 posters were trying to tell me they have FSCM's in their ZL1's and I was politely trying explain that they don't. They have a FPCM that the settings are controlled through the ECM side on HP tuners and a CCM to control the exhaust valves. That isn't the same thing as a FSCM equipped car like the 2014-15 Z28 and 2016 SS has.
Old 08-27-2024, 05:29 PM   #16
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
Thanks for correcting my misunderstanding ! I'm always glad to know the "right" terms etc as related to my car!
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
2023_ZL1-AUTO is online now   Reply With Quote
Old 08-27-2024, 07:42 PM   #17
Camfab
Drives: ‘23 ZL1-1LE
I used love talking in acronyms just to mess with people. Apparently the jokes on me now, because I’m having to look everything up now.
Camfab is offline   Reply With Quote
Old 08-28-2024, 07:18 AM   #18
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
And that's why I was confused. I know the difference but I didn't recognize you said FSCM vs FPCM
GM Gen V Calibrator
Old 08-28-2024, 07:20 AM   #19
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
FPCM = Fuel Pump Control Module
FSCM = Fuel System Control Module
GM Gen V Calibrator
Old 08-28-2024, 05:45 PM   #20
ZLRob
Super Stock
ZLRob's Avatar
Drives: Chevrolet Camaro ZL1
I hope you didn't take what I said as argumentative. My acronym was wrong when I said it for sure but yeah I meant FPCM. Freaking GM and all their different options and RPO codes.
758 HP/ 804 TQ
