Old 08-24-2024, 11:56 AM   #15
Saberscar223
Saberscar223's Avatar
Drives: 2023 Riverside Blue 2SS
So I have my Heads Ported does that also effect what pushrod length I should have? Or is that only milled heads?
Saberscar223 is offline   Reply With Quote
Old 08-24-2024, 12:09 PM   #16
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
Things that will affect pushrod length are head milling, cam, and lifters.
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 08-24-2024, 03:30 PM   #17
Saberscar223
Ah okay, how come most cam kits come with the stock Pushrod length of 7.850?
Old 08-24-2024, 03:49 PM   #18
Hostile_1LE
My stock pushrods were shorter than 7.850. Most cam kits don't come with a single pushrod length, I know for sure that BTR and GPI both have drop-down menus for you to select pushrod length.
GPI cam kit PR length selection:
BTR cam kit PR length selection:
Where did you get your cam kit?
Old 08-24-2024, 07:29 PM   #19
Saberscar223
I ordered mine from BTR over the phone and he chose everything based on what I was going for. And on my receipt it said they were 7.850
Old 08-24-2024, 07:33 PM   #20
Saberscar223
I’m confused is there no set stock Pushrod length? Every car varies? So I would need to measure what I need and THEN order them? I had no idea pushrods were this much a headache.
Old 08-24-2024, 09:00 PM   #21
Hostile_1LE
Yes, I’ve only ever been told to measure pushrod length after everything is all assembled. I was recommended 7.850 but when I measured, 7.850 would have only given me .010 of preload.
Old 08-24-2024, 10:07 PM   #22
GreyGhost702
Drives: 2019 Camaro 1SS1LE
I run caddy race lifters, BTR 220 cam, & BTR chromoly 7.825 3/8” Dia. pushrods. Everything but the cam straight from BTR, cam was 2nd hand but it’s got their laser engraving so I know it’s legit. I can tell you BTR will want to know if their pushrod failed. When I spoke on the phone with their sales tech he was very insistent that I measure my pushrod length before ordering the pushrods, and I was glad I did. 7.850 would still have worked, but I would have been deeper into the lifter than what I wanted to be. Everyone says the GM race lifters are noisy. Mine aren’t. No insulator under the IM either. Just chop and blower whistle.
The fact that your tuner wants you to put the stock pushrods back in would give me pause. The stockers are fine pushrods, but if you’re running an aftermarket cam, springs, lifters and reving higher/faster, then there is a good chance the OE’s may not last in a performance situation. Not gonna say they *will* fail, but compared to any aftermarket chromoly pushrod, I wouldn’t put money on OE’s to last. Might get you by, but I wouldn’t want my car on the Dyno with stockers in the holes.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
