#15 | |
I'm in Lakewood.
Start with an E85 kit, Big Gulp, 103mm, 2650, 3" upper, 10% lower, OEM HPFP, 30+, headers, DSX low side, Might Mouse, Hi-flow cats, tune, and see where that gets you. You're not going to make 1000 whp w/o opening up your engine. I know, I tried. Quote:
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 07-18-2024 at 08:16 AM. |
#16 | |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
2650 (I see R's - is there any difference between 2650 and 2650R?)At the mercy of DSX and their projected Fall release for fueling. I suppose driving the ZLE around in the snow ain't much of an option so why not wait... ![]() My end game is 1,000rwhp corrected sea level. That would make it around 850rwhp actually hitting the pavement up here over 5,000 feet altitude. We do have to push more boost, which we can get away with up here, to make the power.
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily Last edited by dreksnot; 07-19-2024 at 10:38 AM. |
#17 | |
Mine has a single DSX low side and oem hpfp.
I don't believe I've seen anyone here making 850 actual wheel hp on the stock short block and heads. Others here might have. My recommendation is to start your project with heads/valve train because I know you can make 850 actual on the stock block (but mine came apart) Mine is an all-out 390 race motor with E2650 on 100 oct. making ~980 actual wheel at 3500 ft. and I'm adding Meth today. Quote:
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#18 | |
I don't believe I've seen anyone here making 850 actual wheel hp on the stock short block and heads. Others here might have. My recommendation is to start your project with heads/valve train because I know that can make 850 actual on the stock block (but mine came apart) Mine is an all-out 390 race motor with E2650 on 100 oct. making ~950 actual wheel at 3500 ft. and I'm adding Meth today. My $0.02. Quote:
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq Last edited by JSH; 07-19-2024 at 08:42 PM. |
#19 | |
Petro-sexual
I don't see a lot of people talk about larger TBs, and when I do, I see improvements. For example - LMP posted a 2650 video on a C7 Z06 where it picked up a good amount of power over 1000-WHP. I'll look for that one and attach a link. The larger TB, apparently, helped with spinning the blower hard, and helped belt slip. It's probably not necessary until you're over +900, but I haven't noticed enough evidence, nor do I have experience. Hopefully others will share. Katech has a nice bucket that I think they say is good to your power on E'. I have it, and do like it. It has dual DW 400s (one pump has the venturi for the jet pump), and DW has outstanding customer service. I've only dealt with Katechs a little, and like them, too. It's not a billet bucket, but if you don't want to pay for it, I think it's a nice option. It might be easier to upgrade down the road, from what I can tell of the apparent fittings, I think. THPSI has a great kit, too. They are constantly upgrading and improving, too. I think there have been 3-updates since moving over to the current controller. And - the controller has the same ability to compensate, as if I recall, someone here posted that BMWs now have compensation that the Atlas is said to have. I wouldn't count THPSI out, IMVHO. They also have lots of pulley-upgrades, too, so that might be worth looking into, if you haven't already. I've seen several shops say that a stock LT4 short block is good to around the mid-900-WHP. CSP and Nickey (Matt said it) are two I know said it in their videos, and I feel like there are more, and it sounds like the limitation was the half-thrust bearing, instead of a full-bearing, like on LSs. RPM takes many a little past 1000 (mostly Procharger builds), though I think there was a recent Maggie 2650 CT5 Fran pushed past 1000. Anyways - it seems like you'll be near a threshold where you want to end up. JMO. Start at 15:17:
#20 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I know Matt @ Nickey picked up some on a 112 vs a 103 in the 900-1000 range.
Here's some info from Zach @ Katech: https://www.camaro6.com/forums/showp...4&postcount=17
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
#21 |
Petro-sexual
That’s in one of Matt’s THPSI videos, too
#22 |
It's not really the power that limits the stock short block....it's crank flex from spinning a supercharger really hard. Turbos would allow a stock short to go 1100whp +.
#23 |
Petro-sexual
Didn’t Katech take push an LT4 TT long block past, like 1300 FWHP and an TT LT5 to, like, 1400 before it bent rods, too, or something? I know LT5s cranks are slightly improved, too. Coyotes bend cranks, too, apparently. I think Roush just posted they have a shortened hub, or something to keep the blower mess as close to the block as possible.
#24 | |
Moderator
#25 | |
For reference, my 2001 LS1 346 block made 900 on a procharger and N2O.
2020 ZL1LE A10.
#26 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
The stock long block won't live for long pushing 1100-1300HP.
GM Gen V Calibrator
#27 |
Yea, the parts aren't strong enough, the compression ratio is too high, and the clearances aren't designed for extreme boost. Remember, it's marketed to make 650 crank.
2020 ZL1LE A10.
#28 | |
So, is 750-850rwhp a realistic range for an SBE LT4 to live a relative good and long life, of course, with a great tune and fuel?
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
