#15 | |
![]() Drives: 2018 1SS 1LE Join Date: Dec 2012
#16 |
TSP revised the cam lineup after BTR did theirs, so the lobes are easier on the valvetrain components. That being said, for a streetcar I would do the BTR 220. The 225 is only worth about 5whp peak and you lose some low midrange. Might not be a big deal with a manual car, but the 225 on up is where you need to start considering an intake manifold that makes power out to 7k rpm and plan on shifting it around there. I wouldn't be surprised if the 220 cam is faster with the stock ported manifold. You have to look at power under the curve. I would do a LT2 minimum on that setup.
#17 | |
![]() Drives: 2019 Camaro 1SS1LE Join Date: Jan 2024
Also, can't you just put the piston at top and let the valve sit on it? Or is there really that much clearance you wouldn't be able to compress the springs far enough to set the locks back on? I've never done it with the heads on, but I'll want to know for future servicing.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane 7/26/2024 Tuning in progress |
#18 |
I ended up changing the oil pump from the truck to the regular car version and ordered a ported MSD from pray.
While I'm waiting for those to arrive I have another question. Since I plan on keeping this car for a project car for quite a while I was wondering if getting an ATI damper was worth it and if so should I go 10 % UD or regular? I assume my idle rpms will have to be brought up some with the cam anyways but my only concern is I also have beefed up the stereo system in the car and dont want to fry any electronics.
Kooks ceramic coated headers -1 7/8 in. x 3 in
Pray ported 95MM TB Pray ported MSD IM Rotofab CAI BTR 225 CAM PRC 312 CC Ported Heads Katech Oil Pump DSX Flex Fuel E-85 kit QTP exhaust cutouts Full JLAudio Stereo Build w/ 13-W6 |
