#15 |
Moderator
Do not need a separate unlock credit for FSCM on 2016. Only ‘17-up.
#16 |
![]() Drives: 2016 Chevrolet Camaro 2SS Join Date: Feb 2024
TY sir
#17 |
Moderator
#18 |
It takes 3 credits to license all controllers (ECM, TCM, FSCM) on a 2016. Imo ALL A8's should be tuned even if your car is stock. The factory calibration is a good part of the reason why there is so much hate for them.
#19 |
![]() Drives: Blown C7 and 6th gen Join Date: Aug 2012
I still need to make this happen. I purposely bought an HP Tuners unlocked TCM from here so I could keep my factory TCM in please if I ever decided to go back to stock a sell. Some of the reading I have done recently now has me concerned this TCM will not work and the process doesnt work like that??? I hope I am wrong. The seller pulled it from his 2017 SS (like mine) and put the OEM tune back on it.
#20 | |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I also don't know if HP Tuners, when they unlock the 2017+ TCM's, if they are actually programming in your correct learned solenoid flow values based on your VIN. I am thinking they don't. I am trying to remember but when I did mine I think I did get the code that the learned values weren't present and I think I turned that DCT off. I have had the famous 8L90 issues that have got worse with 100k+ miles. The hot 1-2 shift flare at low throttle is probably the most pronounced. Followed by the very unnecessarily hard 3-4 shift at mid throttle. I have also been noticing a new one where going from neutral/reverse to drive starts taking twice as long and then bumps into gear way harder than a normal garage shift. I have the very controversial opinion that apart from increasing the shift speeds and RPM for the bigger cam, there is nothing else I see to really do in the TCM, and its mostly because nothing else has any effect, at least in my specific operating system and calibration. HP Tuners defines a lot of tables and switches, but I haven't found any of them to work or have any effect. To me its 99% in getting the airflow models correct for when you have a cam, and then getting virtual torque corrected as well which will then allow the TCM to control torque through the ECM like it was stock. I haven't really messed with it in a while so maybe things have changed and HP Tuners has fixed and updated some things. They do like to just populate the tune file with buttons and tables like I said, but they seem to be good at looking into things more when you put in a support ticket and describe something that is not working or has no effect, sometimes they will address the issue and fix it in the next beta release. |
#21 |
![]() Drives: 2018 Camaro SS A8 "Dark Knight" Join Date: Oct 2019
I had GPI remote tune my A8, Great customer service quick turn around after submitting my files.
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake |
