#15 | |
![]() ![]() ![]() Drives: 2023 ZL1 - All Bolt On's Join Date: Dec 2022
Here is my build thread for reference: The last few posts as of now show the Katech shop work! (Thanks Mike & Nick and the rest of the Katech Team!) https://www.camaro6.com/forums/showthread.php?t=611982
2023 ZL1 A10-Stainless Works 2" Long Tubes & Legend NPP Axle Back•GESI UHO 4.5" CATs•RF BigGulp•Kong 103mm & X-Ported Blower•Griptech 2.30" Upper•ATI Super Damper w/9.45" Lower•THPSI Port Injection w/875cc Injectors•FI Interchillers Stage 2•Brisk RR14S Plugs•Granatelli Malevolent Coils•Katech Low Profile Billet Valve Covers•Katech Duel Fuel Pump•MM Wild 1000HP•DSX Flex Fuel Kit•DSX Billet Lid•DMS 2gal Fender Tank•BMR Cradle Lockout•Weld Solana 18x8 Fronts/17x10 Beadlocks MT ET ST R's•Unlocked TCM•E85=785rwhp/691rwtq +21psi | 1/4=10.5005 @134.21 60ft=1.6182, 1/8=6.8373 @106.11
#16 |
Fueling is expensive to upgrade, especially if you run E which I recommend. In a manual car +30 injectors and a low side will support 800whp on E60. However, Port Injection offers the best ROI. I still like DI only because it's less clutter in the engine bay, but if the installer takes the time to run the wires and hoses, it can be hidden well.
You are going to be 4-5k for fueling minimum regardless of which direction you go. THP port kit comes in around 3k, then you still need at minimum a DSX aux low side which is another 1200.00. You don't need to do heads, but if you ported them and milled for a little compression bump(10.5-10.8:1) then you would see more than 20whp and it wouldn't be a problem at all if you run Ethanol. This wouldn't be a bad idea because you can make more power on motor and not have to spin the blower as hard. X port really wakes it up the stock blower so good choice there. I would opt for a stage 2 cam instead of the 3.
#17 | |
![]() Drives: 2015 Corvette Stingray Join Date: May 2019
For the 103mm TB here at Soler Performance we sell Ported 103mm TB. Whenever you are ready to get one just let us know. Use discount code SALE5P at checkout. Website: https://www.solerengineering.com/gen...ors/se1000-103 Email: tiffany@solerengineering.com Text/call: (850) 512-9262 |
#18 |
![]() Drives: 2022 Camaro ZL1 Join Date: Sep 2023
Ah the dreaded fuel system limitations. Got to love DI LT motors.
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
With port injection, the sky's the limit on how much power you can make. Sure there's an upfront cost, but the ZL1 costs a good bit less than a GT500 or a Hellcat and at that point you can do whatever you want in a platform that is more capable at doing everything than the GT500 or a Hellcat.
#20 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
To me, if you were going to skimp, hold off on a "bolt on" part you can easily add later.... but when you open the motor.... go all out my friend, because it sucks to open it twice.
#21 |
![]() Drives: Chevy Camaro Join Date: Sep 2022
A few bucks can be saved on the low side aux kit by doing your own lines and pump setup controlling it with the THP reflex plus controller like I did. No need for a separate control method.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels. 1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically '94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake |
#22 |
Correct, but the main point I was attempting to make is the fueling upgrades are going to cost more than what I believe the OP realizes regardless which direction he goes.
#23 | |
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
The biggest crutch on the LT platform is the fuel system. Both high and low side need to be addressed pretty early on to be successful. |
#24 | |
Petro-sexual
It's nice we're getting more options for fueling. Katech came on with a bucket upgrade, which I would have done (before the DSX low-side) if it was available at the time. As JL' pointed out, if you add something like THPSI's PI controller (REFLEX), you can save a little money by not having to purchase a low-side controller, too - which you do. The REFLEX can control the aux' pump, too, and if you don't mind a little fuel plumbing, you can make your own low-side. Be careful exploring bucket upgrades, though. I'm not knocking the Katech bucket at all (I am an advocate of it, in fact), but in the beginning, I didn't understand the pump that's added in the bucket takes the room of the OEM pre-filter. That means, you have the ADD one somewhere. That was a little tricky at first (I haven't done many fuel upgrades, but was up for a challenge), but after figuring out where to put everything, it was relatively easy. DSX is coming (or might be selling already) with a bucket upgrade, too, which is more expensive than the Katech, but is an alternative. The point is, there are more options than ever out there. Take your time exploring them, and make sure they fit your goals, and give you room in the future. Make sure to define goals, first, and go from there. You'll be spending more money for fueling on this platform, but there are more and more options as time goes on. JMO AND FIND A GOOD CALIBRATOR!!! If you read enough around here, you'll quickly see who knows their stuff.
#25 |
Moderator
Bingo. If $5K for fueling is a deal breaker, then you can’t afford to mod this platform.
#26 |
![]() Drives: 2023 ZL1 1LE Join Date: May 2018
Really, you must be Nostradamus?. I paid cash for the car (2023), and have almost 25k into it. Just because I dont "Want to" spend 5k on fuel for an extra 100 hp, doesn't mean I dont have the means. I've done numerous 40-70k builds. You shouldn't presume.
2023 BMW X4M Competition (Downpipes, Midpipes, Intake, Exhaust, Tune)
2023 ZL1 1LE BC Forged KXO5, 325/345 R888R, KPMF Satin Pearl Wrap, 2650/Heads/Cam/3200 stall/Meth- 918 rhwp/842 rwtq, Girodisc/Carbotech AX6, Race louvers. |
#27 | |
I will say, you can make up to 700whp safely on this platform on 93 octane without meth and without having to modify the fueling but if that's not enough power for you, then you have no choice but to modify the fueling. You have been given a lot of great advice here by a lot of experienced people, so the decision is yours on how much you want to spend and how far you want to go. |
#28 |
To add to the OP Q's regarding upgrading the fuel system. My current Katech build that's almost complete includes the Katech dual fuel pump drop-in and THPSI port injection. This allowed the removal of the low side JMS Fuel Booster! One thing I'm personally happy I've not done yet is touch the internals of the engine. I had the blower Kong X-ported, added 2.3" upper, a 9.45" lower and it will run straight E85 (no mixing thank goodness!) For me, this build was worth the cost, although it was up there in price. I feel for me, what I did made a cleaner install/build overall and it'll still drive like a stock ZL1, but with a lot more added power!
