#15 | |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
It feels to me like the DexosR certification program is mostly designed to upcharge the customer. The owner's manual still says it is fine to run 15W-50 full synthetic oil on track (not Dexos 2 or DexosR certified) so I personally doubt the certification means much in terms of actually providing increased engine protection but it is worth the extra money so there's no possible way for a dealership to deny a warranty claim based on your oil not meeting the required Dexos certification. Similarly they've never offered 5 quart jugs of 0W-40 Dexos 2 or R oil in the United States that I could find even though every Camaro with the LT1 engine takes 10 quarts. Individual quarts are usually priced higher per quart than 5 quart jugs. Personally I would not be comfortable leaving 15W oil in my car all of the time because of added cold start wear compared to 0W or 5W (especially when it is cold outside but in general even in the summer) since I drive on the street quite a bit. Last edited by cdrptrks; 08-08-2024 at 12:04 PM. |
#16 | |
The 5 quart jugs of 0W-40 European Car Formula that have been on the market for 5+ years have never been Dexos 2 certified. I guess there's no way to know if the reason is because the oil doesn't meet Dexos 2 standards or because Mobil 1 didn't want to pay the licensing fee when the product is marketed to European cars rather than GM cars. I would guess that it doesn't meet the standards otherwise it would have been cheaper/easier for them to have the same formula/bottle for both European cars and GM cars and just get it Dexos 2 certified. |
#17 | |
Drives: 2021 ZLE, C5 Z06 6.0L Procharged Join Date: Mar 2023
#18 | |
![]() Drives: 22 SS 1LE Join Date: Apr 2022
#19 |
Interesting, they must have changed the bottle since my last big order from AutoZone.com because my bottles have never mentioned European Car Formula.
I guess this improves the odds that ESP X4 actually meets Dexos2 but wasn't tested/certified. |
#20 |
![]() Drives: 2000 WS6 Join Date: Dec 2014
I suspect you're right, but is there any price advantage to ESP X4? Last year you could get that deal with 5 quarts of X3 and an STP filter. I don't think that works anymore, and last I looked, X4 was like $13/qt. May as well just get DexosR from Amazon.
#21 |
Yes, if you click See Available Deals the deal is still ongoing. It has been available every time I've checked for years. Some locations will let you return the oil filters to make the deal better.
https://www.autozone.com/motor-oil-a...rt/1177215_0_0 |
#22 |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
I've been a consistent user of the ESP x3 (cheaper through the Autozone discount and just as good if not better specs than the ESP and Supercar versions). It was important to me that it was Dexos2 rated because I track mine and need the powertrain warranty. Now it is no more, at least under that labeling. If the ESP x4 has a very similar additive pack and the high temp viscosity and flow numbers are comparable to the Supercar, I'd consider using it.
So does anybody know how similar or different the ESP x4 is from an additive package perspective (SAPs) perspective? |
#23 | |
Lake Speed does an analysis of the Supercar 0W-40 in this video below, and touches on the ESP X3. Maybe he will compare the ESP X3 and X4 in a future video. Alternatively you could send the X3 in for analysis and then do the same with X4.
#24 | ||
Lake's vids are a bit hard to follow, but I like the detail he gets into and the fact that he's helping put additional data out there. Especially like the one he did on shear stress test and helping you understand what that tends to do to a variable viscosity oil. |
