Old 05-08-2024, 09:03 AM   #15
L78toLT1
L78toLT1's Avatar
When troubleshooting my car, I picked up a new injector wire harness so I could check the injector signal without having to pull off the blower. It ain't particularly easy, but on my 2300 Maggie equipped
car, you can access the connectors at the back of the motor, without removing the blower. I assume you can with the LT4 blower also. You can plug in the new harness and check the injector signal using void lights that you can borrow from Autozone
Baby Blue
Old 05-08-2024, 09:04 AM   #16
L78toLT1
L78toLT1's Avatar
Noid lights
Baby Blue
Old 05-08-2024, 09:07 PM   #17
Keithj3
Drives: 2016 camaro
Noid lights
Thanks a lot that’s my next step to try! I’m just ready to figure this thing out. Imma do everything you just name and check back tomorrow again thanks man I appreciate the help!!
Keithj3 is offline   Reply With Quote
Old 05-09-2024, 08:04 AM   #18
L78toLT1
L78toLT1's Avatar
Good luck! If the ecm is the issue, there are a few tricks you'll need to know in order to get the new ecm to play nice with the rest of the car, especially if the car is a M6. I can walk you thru it, if needed
Baby Blue
Old 05-11-2024, 12:04 AM   #19
Keithj3
Drives: 2016 camaro
Ok brother soon as I find out I’ll be reaching out to you.
Old 05-14-2024, 04:28 PM   #20
CJZ-SS1LE
Drives: 2022 camaro SS 1LE
I know it sounds weird but the hpfp seal coulda went bad causing all kinds of issues like your having mine did this and it just needed a new hpfp but its worth a look.
2022 Camaro SS 1LE, 427 Darton sleeved, Diamond pistons, Callies ultra rods, Callies crank, King bearings, ARP throughout, Cometic gaskets, large bore ported CID heads, Cam motion custom cam, C7R chain, Katech oil pump, LME chain guide, BTR pushrods, Johnson lifters, MSD intake, Katech 103mm tb, Rotofab cai, Kooks 1 7/8 headers, 3 in mandrel custom exhaust. Hp T93 TCM.
CJZ-SS1LE is offline   Reply With Quote
Old 05-14-2024, 06:44 PM   #21
Keithj3
Drives: 2016 camaro
Interesting is there away to check this? Or do I just have to replace to see?
Old 05-30-2024, 07:34 PM   #22
Keithj3
Drives: 2016 camaro
So guys I’ve tried EVERYTHING basically!!!! New ecm, plugs, wires etc, injectors!!!! What else could it be!!!! Is there anyone that can guarantee to fix or solve this willing to ship ANYWHERE!!!!
