Old 05-10-2024, 12:25 PM   #15
Spudsmaro
Drives: 2021 LT1 6 SPEED MANUAL CAMARO
Originally Posted by ChibbMD View Post
This has all been covered well in other threads, but I thought I'd share the results of my mods over the last few months. I did some fairly simple bolt-ons and accompanying dyno runs to track my progress/gains. I wasn't chasing big numbers. Just wanted to see what I could get out of some basic mods done in the garage. I was pretty pleased. I'll post the graphs later, but here are my results. All on the same dyno. Car is a 2022 SS 1LE.
1. RotoFab CAI and Corsa NPP axle back were my initial mods. First dyno run - 412hp, 458tq.
2. Added MSD Intake (non-ported) and Soler 95mm throttle body. No tune. 428hp, 446tq.
3. Today I got a tune and ended up with 448hp, 433tq.
That's a 36hp (9%) increase. 25tq (5%) decrease.
Nice numbers man. I currently have a LT2 intake manifold, ZR1 95mm throttle body, rotofab cold air intake, speed engineering 2 inch long tubes with their 3 inch catback connected to the stock muffler and E85. Also has almost the entire bmr suspension catalog. Running 305s on rear and 245s on front.
My car dyno’d at 450 Rwhp and 480 torques, when you get long tubes your torque should go back up.
Every dyno and every engine are different so don’t take these numbers too serious, the way the car performs is what counts. Smiles per gallon.
Spudsmaro is offline   Reply With Quote
Old 05-10-2024, 04:02 PM   #16
ChibbMD
Drives: 2022 SS 1LE
Thanks and well stated. I've enjoyed having an affordable shop with a dyno close to home so I can get some pulls done between mods. While it's always tempting to look at the final numbers, seeing the changes between mods is honestly a better use of the dyno.
And to the other post about a ported intake, I've heard a few things. A few folks have said porting an LT2 takes away too much material and makes the "neck" of the intake too thin. That said, plenty of people do it.
Ultimately, I bought the MSD intake simply because I liked the look of it better than the LT2 with a Corvette cover on it. My MSD is not ported, and given my 95mm throttle body and relatively basic modification plans, I didn't see the value in porting. That was just my personal conclusion based on my research.
ChibbMD is offline   Reply With Quote
Old 05-10-2024, 04:12 PM   #17
ChibbMD
Drives: 2022 SS 1LE
And just to continue the thread about my modification plans, I went ahead and purchased the DSX Flex Fuel kit.
Here in my area I've got E close to home. It's currently $2.79/gal vs $3.99/gal for 93. My NA SS 1LE can handle straight E from the pump with no mixing, and I'm probably going to pick up 20-30hp. It was a no brainer for me!
When everything is installed, tuned, and dyno'd in the next week or so, I'll be sure to update this thread with the numbers.
Old 05-13-2024, 08:27 PM   #18
eaglesfan2006
Drives: 2019 1SS 1LE Riverside Blue
Anyone do a stock dyno? Curious how much of an increase bolt ons are compared to stock.
I’m considering rotofab, 95TB, IM (not sure which one yet), and of course a tune. Maryland has 3-4 E85 stations so that’s lower on the list luckily one is about 20 minutes from me.
eaglesfan2006 is offline   Reply With Quote
Old 05-13-2024, 09:23 PM   #19
White1SS
White1SS's Avatar
Drives: White 2024 1SS M6
Did you do a fully stock dyno pull prior to the CAI and Corsa NPP to know if they netted any power gain ?
White1SS is offline   Reply With Quote
Old 05-14-2024, 05:12 AM   #20
s346k
s346k's Avatar
Drives: like an old lady
i didn't spend much time racing dynos, but with basic bolt ons my 18 ss 1LE picked up almost 10 mph in the 1/4 mi. and another 2 on top of that with a 26" drag wheel.
2" headers, orx & custom 3" exhaust
slightly modified rotofab
mamo ported msd
stock lt5 tb
ati damper
ethanol
potent combo in the right hands
Old 05-14-2024, 07:26 AM   #21
RideWithDanger
RideWithDanger's Avatar
Drives: 23 2SS 1LE
Dyno isnt that important unless you are just chasing numbers, but depending on which exact mods you do. Full bolt on is usually 40-60hp over stock. Remember some mods push that number up higher in the RPM range while others give a smaller average over more of the RPM range, so peak power isn't all that important anyway.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback
Radiant Red 23' 2SS 1LE
1100: 11/14/22 | BUILT: 3/16/23
2000: 2/17/23 | 4200: 5/8/23
3000: 2/27/23 | 5000/6000: 5/15/23
RideWithDanger is offline   Reply With Quote
Old 05-14-2024, 11:09 AM   #22
ChibbMD
Drives: 2022 SS 1LE
No, I wish I would've, but my impression from my research is that they probably didn't add much. I was at 412hp with those items already added. I know you can't compare dynos apples-to-apples, but a number of folks have said stock hp was in the 405-410 range. I bet that's pretty close to where I was.
I also think RideWithDanger is pretty spot on that bolt-ons and tune are probably good for 40-60hp.
Old 05-14-2024, 11:21 AM   #23
White1SS
White1SS's Avatar
Are you M6 or A10 ? I know M6 cars dyno 15-20hp more than the A10 when stock.
Old 05-14-2024, 01:07 PM   #24
ChibbMD
Drives: 2022 SS 1LE
M6
Old 05-15-2024, 10:25 AM   #25
wnta1ss
Drives: 2017 Camaro 1SS
Someone tested an MSD intake manifold and a ZR1 (95mm) throttle body on an SS, with graphs comparing to stock. Thread here https://www.camaro6.com/forums/showthread.php?t=535959
Summary, the MSD intake manifold alone gained 17.48 hp and 10.15 lb/ft over stock, and the MSD intake manifold plus the 95mm throttle body gained 25.90 hp and 15.80 lb/ft over stock in their tests.
Jannetty posted an SS test years back, but the graphs don't work anymore. From what I recall, his gained 16 hp with the MSD intake manifold, and the Rotofab CAI gained 6 hp for him.
Old 05-15-2024, 05:27 PM   #26
ChibbMD
Drives: 2022 SS 1LE
I lost torque with my mods, but was under the impression that HP and torque might be a bit of a trade-off for one another depending on your modifications. My results seemed to confirm what I had read about that. As someone else mentioned, I might be able to regain my torque if I added headers.
Old 05-16-2024, 01:40 PM   #27
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Gotta say I did jump on the MSD/95mm TB talked about in wnta1ss's old thread. Non-ported MSD and unported 95mm. No tune. Car continued to run very strong without adverse effect. My seat of the pants dyno said Tick wasn't blowing smoke (and hey, if "oldman" sez it works...).
Ventmaster is offline   Reply With Quote
Old 05-17-2024, 11:37 AM   #28
wnta1ss
Actually, I think that the torque numbers they gave you are messed up. Your baseline pull has torque more than 11% higher than hp, hmmm. Knowing that the LT1 engine has been rated by the SAE as 455/455, and that most stock SS dyno tests that I've seen have had torque within 2% of the horsepower (mine was within 0.5% BTW), it looks like an issue with that dyno. Possibly the rpm signal has been having a problem. What do the graphs look like?
As far as the hp vs torque trade-off, with your current mods, I would indeed expect a larger gain in hp than in torque, such as the thread that I'd linked shows, but I don't believe that you actually lost 25 lb/ft of torque from the MSD/95/tune. To me, those torque numbers point to a problem with the test equipment. Which sucks, since you are doing it right by attempting to track these mods on the same dyno.
