#15 |
Electrical Engineer
Sounds like you have a crankcase ventilation issue, hence the excessive pressure and excessive oil collection in the catch can.
In your first photo, you're low on coolant. The top reservoir should be full. This could be a sign you're losing some into the cylinders. Both things can be true. Excessive crankcase pressure can cause a head gasket failure, which would be where the coolant is coming from. And this could correlate with letting off the throttle. The gas in your oil is from your rings not doing their job. Also, could be exacerbated by crankcase pressures, but it's also a known side effect of running a Turbo 4cyl these days. It's important to do more frequent oil changes if you're not driving long enough to burn the gas off. And it makes sense the catch can would have gas in it, if that's the case.
2023 1SS A10 Black H72/C2U/56W/NPP
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 64k mi. @ Apr 2026 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
#16 | |
Below is the description of PCV operation for the I4, taken from the repair manual. This system is more complex because of the turbo. DESCRIPTION AND OPERATION > CRANKCASE VENTILATION SYSTEM DESCRIPTION > OPERATION The primary control is through the positive crankcase ventilation (PCV) valve (2) which meters the flow at a rate depending on intake manifold vacuum. The PCV valve is an integral part of the camshaft cover. Fresh air is introduced to the engine through PVC (1) under normal operating conditions. If abnormal operating conditions occur, the system is designed to allow excessive amounts of blow by gases to back flow through the crankcase vent valve (3) into the intake system to be consumed by normal combustion. Only on turbocharged engines, there is a one way valve (2) in the camshaft cover in order to prevent the crankcase from being pressurized by positive pressure in the intake manifold when the turbocharger is in operation. When the turbocharger is operational, the pressure in the intake manifold can exceed atmospheric pressure which, without the one way valve, would force oil and PCV gases out of the camshaft cover and into the induction system, via the hose to the camshaft cover. This can cause coking of the throttle body and induction system, and can reduce the efficiency of both combustion and the intercooler system, in normal operation the PCV gases are drawn into the air stream post intercooler (6). However, when the turbo is spooled up the turbo can become the vacuum source for the vent system. PVC#4 controls the max. flow so the crankcase stays at a normal vacuum during normal operating conditions. |
#17 |
![]() ![]() Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
Why 2 catch cans? My worry is oil somehow getting into the engine/intake (excessive pressure???) and making the white smoke. More like 1 of the lines is routed incorrectly.
#18 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Taking the oil cap off and the squealing stops is the key here.
You're pulling too much vacuum on the crankcase and its actually drawing air into the engine through the crank seal. That is the squeal you hear. Remove all of your catch cans and PCV system back to stock. Don't put catch cans on STOCK cars.
GM Gen V Calibrator
#19 | |
![]() Drives: 2019 Camaro 2.0t Join Date: Nov 2022
again, I appreciate everyone's help, and time responding back. |
#20 | |
Thanks, |
#21 |
![]() Drives: Camaro Zl1 Join Date: Jun 2023
I'm curious what other bolt ons you have? You say. Air intake? Exhaust? Headers? running these kinds of bolt ons for any length of time without a tune? Just saying mine did not run well without a tune the minute i changed the headers... Was told it could run that way and sure enough it couldnt... Was forced to tune it and since that was the case i opted for 2 different tunes i could load up when stopped... The air/fuel ratios aren't something you should leave to the computer to compensate for imo it doesn't do a good job, it will just consistently pour more fuel into the mix because of the increased air and will run like crap. Or like in ur case it won't be able to pour enough fuel into the mix which is why ur getting that lean code. I've seen some of these guys trim the ratios as they are running it on a dyno. Smoothing out the jagged edges and making a smooth flowing overall map. It makes a difference. I can't see having catch cans as a problem. i run 1 with no issues. These LT engines were built for modification. Recommending people go back to stock defeats the purpose of upgrades :P.. As much as i'd like to go back to tuning with a screwdriver, we can't with these cars. So obviously do a proper install, and then get it tuned. 1 Last thing i want to mention, Camaros have this nasty issue with regards to getting air.. I had to bleed my freaking maggie supercharger to stop it from blowing the plastic cap on the reservoir, eventually i changed it to a metal 1 with a overflow spout , no issues once bled.
ps Anyone know if theres a way to load up tunes on the fly? i'd appreciate any info. Last edited by Thestormoverkrynn; 06-14-2024 at 02:40 AM. |
| Tags |
| exhaust, ltg, oil, smoke |
