Old 04-12-2024, 12:31 PM   #15
Deacon Blues
Drives: 2024 Camaro 1SS M6
Originally Posted by SSShark View Post
I have no affiliation nor am I getting compensated, but I just bought a set of these to try them out. Seems like a great solution. I should have them next week. It'll eliminate the need to use jack stands in addition to a floor jack.
https://agatools.com/products/copy-of-jack-rod-stand
Nice! I bought a similar product from zl1addons, it locks the jack in place. Still don't trust jacks even with these failsafes, but does provide a little more peace of mind.
https://zl1addons.com/products/floor...y-stop-daytona
Deacon Blues is offline   Reply With Quote
Old 04-12-2024, 01:37 PM   #16
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
As long as these products prove to be safe, I'm on board.
Kooks 1-7/8" Long Tube Headers l Kooks Hi-Flow Cats l Kooks X-Pipe l Borla S-Type NPP Exhaust
GPI SS2 Cam l GPI Ported Heads l Katech Oil Pump l Katech Valley Cover l GPI Hardened Pushrods
BTR Valve Springs l Johnson 2110R Lifters l Ported LT2 Intake Manifold l Ported 95mm LT5 TB
Rotofab CAI l Mishimoto Catch Can l DSX Flex Fuel Sensor l 93/E85 Tune
BMR Rear Cradle Lockout Kit l Katech VVT Delete kit l CHE Trunion Upgrade l LT1 HPFP
LME/GPI Timing Chain Guide l Katech Timing Chain l AFM Delete
Halo Tunnel Brace l MRR 1LE Wheels l Goodyear SC3 1LE Tire Package l GM Lowering Kit
SSShark is offline   Reply With Quote
Old 04-12-2024, 02:37 PM   #17
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
Originally Posted by Annihilate View Post
So if the lift pads aren't meant to be used with jackstands, then they only serve to be used with an actual lift? This is certainly news to me, and I am glad I am hearing it now! They should really provide more information on the website as to the proper use and function of these things.
I took a cursory glance at the video, I can't play it with sound at this time, but it appears he's using two jacks to lift the front? My confidence for lifting this thing has waned, and I certainly can't afford any lift system at this time.
This is interesting to me as I was hoping to keep the stands away from any paint underneath.
I will have to do some thinking here on how I am going to go about this. Looks like I'll be in the market for an additional jack as well as the lift pads/mag pad.
Is there any reason as to why one shouldn't use the lift pads as the location for the jackstand? Is it simply unsafe/unsturdy?
In the body-repair section of most auto parts store, they sell packages of fiberglass matting. I've used them for a long time as a cushion between the jack/jackstands and the car. So far, the only thing getting "chewed up" or marked up is the plastic baggie the matting comes in and of course the matting itself.
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 04-12-2024, 02:37 PM   #18
split_bumper
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper
I also used the amazon lift pads on my ZL1. $34 and I milled an edge so they fit flush and properly supported. The ZL1 addons ones come pre milled and properly fitted I would imagine.
The biggest thing I feel with using jackstands in conjunction with these lift pads is using the circular topped pads rather than the metal forged "claw" tops. Less chance of stuff moving around and sliding that way, especially when you're jacking it up on an angle.
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531
split_bumper is offline   Reply With Quote
Old 04-12-2024, 03:34 PM   #19
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Yes, the flat top stands are recommended. I don’t have any, so I use strip from an old leather welding glove as a friction adder between the two metals.
Old 04-12-2024, 04:26 PM   #20
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
I use a pinch weld lifting puck on my floor jack to lift at the center of gravity pinch weld (in-line with the steering column), it lifts the entire side at once. I then just use jack stands under the ZL1 addon lifting blocks on that side. The blocks are sized well for my jack stands.
It's pretty easy.
Daily Driver mileage update: 64k mi. @ Apr 2026
Old 12-29-2025, 04:15 PM   #21
Capricio
Drives: 2000 WS6
It's pretty easy.
Just throwing this out there, for the fairly large number of HF Daytona Jack owners....
https://www.slashgear.com/2029725/ha...-weld-adapter/
https://www.harborfreight.com/magnet...ter-70888.html
Capricio is offline   Reply With Quote
Old 12-30-2025, 11:17 AM   #22
DeuceCam
Drives: LT1
^Thanks for the link. The adapter looks decent and is less expensive than other popular alternatives. It might even work with other jacks from the looks of it (description.says 'universal').
DeuceCam is offline   Reply With Quote
Old 01-17-2026, 11:34 AM   #23
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
This link may be a newer model than what I have, but I bought the Esco flat-top stands when I got my first sixth gen (in 2017), and they have worked great with the ZL1 lift pads.
https://esco.net/product/3-ton-perfo...ck-stand-pair/
