Old 04-15-2024, 12:52 PM   #15
Dennis 2ss
Dennis 2ss's Avatar
Drives: Camaro 2SS 2017
Originally Posted by ctrlz View Post
Good idea.
see if level is high and it smells like gas.
logs.zip
Here is some logs at least. I don't have my car right now as my tuner is working on it but all your help is worth a lot!
2SS A8 D1X Stage 2, 3.7 pulley, Kooks LT 2″, Borla XPIPE/ GPI drop ins,Caddy Racing Lifters, ATI Damper, LPE GT35 Cam 42%, LPE Big Bore, FIC 30% Injectors, Fore Twin intank pumps, Flexfuel, MM wild catchcan.
865 WHP 743 LB FT
2Forge 19" wheels daily, Forgestar D5 17" for track
Dennis 2ss is offline   Reply With Quote
Old 04-15-2024, 05:22 PM   #16
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by Katech_Mike View Post
Have you checked the oil?
Originally Posted by Dennis 2ss View Post
definitely has oil dilution. 100% smells like gas.
Yep, Mike probably has this sniffed out…probably a bad HPFP
Old 04-16-2024, 09:41 AM   #17
ctrlz
I would think a failing pump would develop lower pressure, and that would not cause fuel to get past the injectors. I would expect lean problems.
Old 04-16-2024, 11:53 AM   #18
Owl3
Drives: 24 Sliverado 1500 ZR2, 2017 ZL1
Could it be a physical leak? Since it's located in the valley maybe the leaking fuel would just end up in the oil returning to the pan.
Finally on the way to 1K.....
Owl3 is offline   Reply With Quote
Old 04-16-2024, 02:21 PM   #19
Katech_Mike
Drives: 2015 Camaro ZL1
Yes.
The internal shaft seal can fail. This causes fuel to dump into the crankcase. If you continue to run it like this it can cause bearing degradation.
This is typically caused from improper pump preload. Usually the pump is bottoming out.
Katech_Mike is offline   Reply With Quote
Old 04-16-2024, 10:17 PM   #20
Dennis 2ss
Dennis 2ss's Avatar
Yes.
I believe this is what happened.
865 WHP 743 LB FT
Old 04-17-2024, 08:55 AM   #21
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
This thread seems to mimic similar issues.
https://www.camaro6.com/forums/showthread.php?t=623067
Old 04-17-2024, 09:08 AM   #22
ctrlz
Sure does.
Yikes, that's a mess!
I would think the entire engine bay would reek of fuel.
Old 04-17-2024, 10:21 AM   #23
KingLT1
KingLT1's Avatar
Sure does.
I am pretty sure we are dealing with a similar issue on my brothers C7 Z06 that has H/C 2650 with XDI +65 and LPE HPFP. All of a sudden, the idle fuel trims are -35. No matter what I do to the MAF or VE it doesn't change. Actually, it gets worse as I try to reduce fuel and honestly it should be lean.
Old 04-17-2024, 10:28 AM   #24
Dennis 2ss
Dennis 2ss's Avatar
Yup this literally exactly the same as me. This sucks as the LPE pump is 3k. But then again the motor could have gone too...
865 WHP 743 LB FT
Old 04-17-2024, 10:36 AM   #25
Dennis 2ss
Dennis 2ss's Avatar
mine had all the same issues but the intake is completely dry. Catch can was completely full of alcohol
865 WHP 743 LB FT
