Old 03-31-2024, 10:00 AM   #15
White1SS
White1SS's Avatar
Drives: White 2024 1SS M6
Originally Posted by SamSmoothCastel View Post
your OE rims just fit and look better. Its probably just me but everyone and their mother has the 1LE reps now.
That's because they look so good. lol
If my OE rims were 11" in the rear I would probably keep them for awhile and go with a 305 or 315. From a visual prospective I just think a 275 in the rear is not wide enough, and I don't think I can safely go any wider than a 285 on the OE 9.5" rim.
White1SS is offline   Reply With Quote
Old 03-31-2024, 01:21 PM   #16
david_acm
david_acm's Avatar
Drives: LT1
To be fair, 1LE wheels are the probably the best looking OEM set on a Camaro.
david_acm is offline   Reply With Quote
Old 03-31-2024, 01:33 PM   #17
Yup. The wheel designer somehow hit a magic unicorn spot with this design, plus it ages perfectly and nothing comes close even after several years. I tried.
For the record, I'm definitely *not* saying nothing else looks good, there are several worthy competitors, it's just that the SS 1LE wheels look astoundingly good and fit the body design extremely well.
Old 03-31-2024, 01:58 PM   #18
Curr
Probably doesn't like you
Curr's Avatar
Drives: 2022 WCT ZL1 M6
Yup. The wheel designer somehow hit a magic unicorn spot with this design, plus it ages perfectly and nothing comes close even after several years. .
100% agree.
Hell, I tried to find something very similar to put on my 911S!
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Quod gratis asseritur, gratis negatur.
There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly.
Curr is offline   Reply With Quote
Old 03-31-2024, 05:57 PM   #19
White1SS
White1SS's Avatar
Does anyone know if the rear drivers side wiring harness still needs to be relocated on the 2024's?
I think I'm sold on the 315/30/20's and the 275/35/20's. I wish they made the 1LE replica rims in 9.5" and 10.5", I like the look of a tire on the more narrow rim within its safe range.
Old 03-31-2024, 07:02 PM   #20
Curr
Curr's Avatar
You should be able to feel it through the liner iirc.
كافر
ΜΟΛΩΝ ΛΑΒΕ
железобетонное очко
Old 03-31-2024, 09:28 PM   #21
White1SS
White1SS's Avatar
I know the general area to look for it, if GM has relocated it from previous years I'm guessing there won't be a little bump there?
Old 03-31-2024, 10:36 PM   #22
havelegs
havelegs's Avatar
Drives: 24 LT1 M
They look great ! It looks like you have matte or satin side skirts and splitter? With the front poke I wonder if a little more stagger would look good, maybe a 275 in the front. What brand tire did you go with ?
Yup, matte/satin/unpainted (whatever they are considered) side skirts and splitter. I like the look of it rather than any gloss. My previous LT1 (which was stolen), I had glossy zl1 style skirts on it along with black glossy door handles. I added glossy zl1 style wheels on it too, but after all of it I really didn't like the gloss look. This car, I went with the matte look, I think it looks much better.
I think it's just by design with the wheel poke because the 285s don't really overhang the wheel, just slightly. I think 275's would be fine too.
I went with Bridgestone Potenza Sport, Tirerack has "old" tires on sale which I snagged up for under $800
https://www.tirerack.com/tires/tires...formance%20Pkg
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 04-28-2024, 10:03 PM   #23
White1SS
White1SS's Avatar
Have any SS/LT1 owners noticed a minor loss of straight line acceleration when switching to wider/heavier tire/rim combos? Assuming similar height tires as factory spec, the added MOI of heavier wheels has to have some affect on performance. On the other hand, maybe a wider 305 or 315 can hook on the street and foster faster acceleration due to traction control cutting power to a spinning 245 or 275.
Old 04-28-2024, 10:33 PM   #24
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I went from stock SS wheel/tires to 1LE spec MRR017s and feel I gained a LOT of traction vs the factory run flat 275s..
Old 04-28-2024, 11:09 PM   #25
White1SS
White1SS's Avatar
Do you feel the car would be quicker in the 1/4 mile now ?
Yes better traction, but also more rotational mass eating up power. And of course the added rotational mass of the wider/heavier fronts can only hinder straight-line acceleration. On paper the 1LE spec has to be slower in the 1/4 unless better traction can mitigate the higher MOI of all four wheels. At SS power levels, I don't see how a 1LE spec could win in a roll race as well.
Don't get me wrong, I'm putting 315's on the back of my car, I don't care if it costs me a bit of acceleration or not, they look awesome ! lol.
Old 04-28-2024, 11:15 PM   #26
2SS Capt
2SS Capt's Avatar
That is beyond my experience level, but before when I used to spin, I now hook, so to me, that makes it much faster... I have 305/30s out back, when it is time to replace, I'm going 275/35 (front) & 315/30 (back)... Love the wide look!
Old 04-28-2024, 11:34 PM   #27
White1SS
White1SS's Avatar
That's the same spec I'm about to order...275/35/20 and 315/30/20. I'm going with Atturo AZ850's, they are nearly identical in height to each other, and with factory spec tires. Every time I'm behind a 1LE with 305's, or a Wide Body Scat with 315's, I know the 275's have to go. lol
Old 04-29-2024, 12:42 AM   #28
2SS Capt
2SS Capt's Avatar
I have the exact same tires, I bought them from a friend VERY lightly used (he went with street drag radials), for the price they can not be beat! I currently have 285/30 & 305/30 but when it comes time to replace going with 275/35 & 315/30 as like you said, they are nearly identical to the SS OEM diameters...
