Old 02-12-2024, 09:51 AM   #15
Drnick
Drives: 22’ ZL1
I replaced battery with a new Duracell, checked voltage
And it was 3.04 volts , still didn’t work! Somehow, when I
Changed battery, it lost its ability to communicate with car
It has to be re- programmed! It’s a process!! Somewhat
Involved!!!!
Drnick is offline   Reply With Quote
Old 02-12-2024, 09:56 AM   #16
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
The reason I suggested swapping batteries between the working remote and the non-working remote is to eliminate any variables, if the battery works with the working remote, then it should work in the non-working remote if it’s only a battery issue.
Old 02-12-2024, 11:58 AM   #17
roostere4
Drives: 1987 IROC, 2020 ZL1
I second the idea of switching batteries from the "good" FOB to the other. The Other remote is still programmed to the car or you couldn't start the car with it in the cup holder. Now there are relay only 2 things that I believe could be here, since the "good" remote works. Your non-working remote doesn't have enough power to transmit. So check using a known good battery from a working remote, and check that out is inserted correctly. If this works you just need to get another battery. If this doesn't work there is an issue with transmitter in the fob and you most likely need an entirely new fob
roostere4 is offline   Reply With Quote
Old 02-12-2024, 01:27 PM   #18
Drnick
Drives: 22’ ZL1
Battery is new, and a Duracell, and
It had 3.04 volts before I installed it
It’s not the battery, it’s probably the
Fob or a re programming issue,
I’m reluctant to remove the battery
On a working fob, as it seems the defective
FOB stopped working when I installed new
Battery, unfortunately I might have to take
It to Stealership and have a “Tech” try to
“Fix” it! Good Grief!
Old 02-12-2024, 02:25 PM   #19
CalgaryZL1
CalgaryZL1's Avatar
If you check your owners manual, on page 13 section “programming without recognized transmitters” it’s a lengthy process but if your key fob is still good, it should reset it. The downside is you have to reprogram your working key also.
Old 02-12-2024, 04:25 PM   #20
Drnick
Drives: 22’ ZL1
Oh great! But then I have to do both
Old 02-15-2024, 06:37 PM   #21
Foggx
Foggx's Avatar
Drives: Camaro ZL1 2022 Shadow Gray
I just ran into the exact same issue. Keyfob stopped working. Put new batteries and no change. Ended up buying other brand batteries, and the keyfob started working again, even tho the other ones were new and showing 3V. I'd suggest you try different batteries! Worth a shot, I thought mines were dead.
Foggx is offline   Reply With Quote
Old 02-16-2024, 05:43 AM   #22
Drnick
Drives: 22’ ZL1
I had key fob tested by my dealer ,found key fob
Was defective, they ordered new fob under warranty
So, it wasn’t battery, it was FOB
Old 03-05-2024, 10:13 AM   #23
Foggx
Foggx's Avatar
Thanks for your answer. Good to know in case it happens to me again.
Old 11-16-2024, 07:51 AM   #24
paradigm
Drives: 2022 Camaro 1SS 1LE
Did you figure out the problem?
Looks like I’m having the same issue on my 2022 SS 1LE
One fob works the other stopped.
paradigm is offline   Reply With Quote
Old 11-16-2024, 03:38 PM   #25
Keko
Keko's Avatar
Drives: 2023 ZLE M6
read 2 posts up from yours
2023 ZLE M6
Borla S-Type Catback | Rotofab CAI | Soler TB | MPI Lid
2024 Polestar 2 AWD
Keko is offline   Reply With Quote
Old 11-07-2025, 03:54 PM   #26
20204
Drives: Chevrolet Camaro 3LT
It’s not the battery, DIC still says “no fob detected “
It does work when I put fob into cupholder?, but it won’t
Lock or unlock car or open trunk? The spare fob works
Fine.PS car does start and run, but only when I have
Fob in cupholder
I only have one key and i'm in the same situation. but randomly sometimes the car will detect the key and then it randomly stops. i thought it was the key fob but i inspected and changed the battery and when the car does detect the key fob, the fob does everything it's supposed too. the car just decides to not detect it sometimes. what is going on? some type of receiver?
20204 is offline   Reply With Quote
