Old 02-08-2024, 12:16 PM   #15
Bigpoppa09
Bigpoppa09's Avatar
Drives: 19Camaro 2SS/ 22 Charger Scatpac
Originally Posted by Need4Camaro View Post
Sluggish start = Battery Problem. Alternator plays no role in how the car cranks. Your battery is from 2017 and has exceeded its life expectancy by a fair margin, you need to replace it asap.
The alternators on these cars are not always charging, they only activate when the voltage drops below a certain level, otherwise the battery is propelling the car. This was done to conserve fuel.
The alternator may be on its way out too, but your battery definitely needs to be swapped out.
Battery was swapped 2 weeks ago.
Bigpoppa09 is offline   Reply With Quote
Old 02-08-2024, 02:33 PM   #16
scott_0
scott_0's Avatar
Drives: 2018 Hyper Blue Metallic SS 1le
does it start fine now? as said, these alternators and gauge aren't like we're used to, they will show actual voltage of the battery, then show charge voltage when the battery needs a charge.
When I bought my 2018 in October, I was ready to panic on the 150mi drive home as I was seeing the same as you, I came home and did some research and sure enough, it's normal.
scott_0 is offline   Reply With Quote
Old 02-08-2024, 08:27 PM   #17
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
Thank you, I always wondered wtf was up with that damn gauge!
speedyink1 is offline   Reply With Quote
Old 02-09-2024, 04:21 AM   #18
Bigpoppa09
Bigpoppa09's Avatar
Yes it starts fine
Old 02-09-2024, 05:19 AM   #19
Originally Posted by Bigpoppa09 View Post
Yes it starts fine
So then all you're seeing now is the dual mode (battery / alternator) voltage gauge at work, as described in the manual and ctrlz's other post referenced above. As long as the displayed voltage drops to 12.5-12.7 V once the alternator is done charging it on a relatively longer drive, your battery is fully charged and working normally at that point.
If you still see sluggish cranking when (re)starting the engine shortly after a drive, there is another thread about sluggish warm/hot starts here, you might want to check it out: https://www.camaro6.com/forums/showthread.php?t=586153
Old 02-09-2024, 06:41 AM   #20
Bigpoppa09
Bigpoppa09's Avatar
So then all you're seeing now is the dual mode (battery / alternator) voltage gauge at work, as described in the manual and ctrlz's other post referenced above. As long as the displayed voltage drops to 12.5-12.7 V once the alternator is chargnig it on a relatively longer drive, your battery is fully charged and working normally at that point.
Thanks for the info👍
Old 02-09-2024, 06:46 AM   #21
ctrlz
Yes it starts fine
It may not call for charging until the battery voltage dips, but I would think after 2 weeks on a new battery it should be calling for 14 V charging at some point. With no recharge the battery voltage will just steadily drop.
If any reliable meter connected directly to the battery is reading 12.0 V, that is VERY low state of charge.
Old 02-09-2024, 07:56 AM   #22
scott_0
scott_0's Avatar
Yes it starts fine
sounds normal to me then...
Old 02-12-2024, 11:28 AM   #23
1LEASYE
Drives: 2018 Camaro 1SS 1LE
You might have the same problem I did last spring where the control board that is hooked to the ODB port under the driver's side dash was dying in my car and it kept cutting the electrical components of the car off while driving even after replacing the battery and verifying the alternator was fine. I replaced the board and that was it and haven't had a problem nearly a year since.
2018 Camaro 1SS 1LE
1LEASYE is offline   Reply With Quote
Old 02-13-2024, 08:26 PM   #24
Summit20171SS
Summit20171SS's Avatar
Drives: 2017 1SS M6
Mine just starting doing the same thing after installing a brand new battery, today while driving it was at 10, and sometimes went up to 14 when the accessories were on, seems to be normal from what Ive been hearing
2017 1SS M6
~ Air Raid Cold Air Intake~ ~ 3" Corsa Extreme Catback Exhaust ~
Summit20171SS is offline   Reply With Quote
Old 02-14-2024, 10:44 PM   #25
MyNameIs
Drives: Camaro SS
Mine also a 17' SS. I replaced my Battery 2 months ago. It was working fine, but with 68k miles a 6 years I wasn't going to chance it. Just a matter of time. Holy sh!t...hard to believe my car is 7 years old now. Still runs and looks like new.
MyNameIs is offline   Reply With Quote
