Old 03-16-2024, 06:33 PM   #15
Summit20171SS
Summit20171SS's Avatar
Drives: 2017 1SS M6
Originally Posted by ctrlz View Post
Don't see a magnet here. And no electrical connections to the shifter itself.
There is at least one good photo of the underside in this listing. Ebay is often better than GM parts sites for photos.
https://www.ebay.com/itm/26474747849...3ABFBMoK2e9Mhj
Its called a shift fork position sensor.
https://www.gmpartsnow.com/oem-parts...a&gad_source=1
2017 1SS M6
~ Air Raid Cold Air Intake~ ~ 3" Corsa Extreme Catback Exhaust ~
Summit20171SS is offline   Reply With Quote
Old 03-17-2024, 07:35 AM   #16
ctrlz
Basically the same as this one I posted above. Only differs by last digit in part number.
This bolts to the side of the tranny.
https://caryparts.hendrickcars.com/o...ensor-24283437
Old 03-17-2024, 04:47 PM   #17
Summit20171SS
Drives: 2017 1SS M6
Yes you were correct! So far its been good since the repair
2017 1SS M6
Old 04-09-2024, 02:30 PM   #18
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Good to know info, thanks for posting. Shame it requires (apparently) programming from the dealer after install. Looks as if it would be an easy DIY otherwise. Nice choice on your model/color too. How many miles on the car and how much did the dealer set you back for repair if you don't mind saying? Thanks again.
Ventmaster is offline   Reply With Quote
Old 04-09-2024, 03:27 PM   #19
ctrlz
I doubt this requires any dealer programming.
The position sensor relies on a magnet attached to the gear selector within the transmission. As that magnet moves around with different gears it triggers sensors (Hall effect) within that rectangular unit bolted to the side of the tranny.
Old 04-09-2024, 09:45 PM   #20
Summit20171SS
Drives: 2017 1SS M6
Yes exactly what ctrlz said above. Thank you ! I have 47k on her, and repair was covered in full under warranty
2017 1SS M6
