Old 01-26-2024, 06:32 PM   #15
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by CalgaryZL1 View Post
Does anybody know the part number for the factory GM LS3 thermostat? I would like to order one as a spare on hand in case the motorad 180 craps out. Thanks.
I think the problem there is the factory LS3 one is 194 degrees so that’s why everyone runs the Motorad 523160 one since you can get it in 160 degree set point.
Old 01-26-2024, 06:33 PM   #16
Joshinator99
Moderator
Originally Posted by 2018ZL1 View Post
Gotcha... I need to open my eyes a bit more!
No worries my man!
Old 01-26-2024, 06:53 PM   #17
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Yes, I understand the different degree options. I would just like a factory one on hand, if I recall I think they have 187°. I have read they are possibly more reliable. And a spare on hand never hurts no matter what the degree setpoint is, I don’t track my car I just didn’t want a plastic housing.
Old 01-26-2024, 07:05 PM   #18
CalgaryZL1
CalgaryZL1's Avatar
Actually, I think I just found the part number, but not 100% sure as I am not an LS3 motor guy. Gm # 89018168
Old 01-26-2024, 09:23 PM   #19
pitrott1
OSCM(SW) USN Ret.
pitrott1's Avatar
Drives: 2023 Camaro 2SS-1LE VOM 6M
I just bought this! includes the 180% thermostat..
2023 2SS-1LE VOM, 6M, SR S-TBrace, A-PDL's, Fuzzy suede KP's, NAV
1100 3/29/23
2000 3/30/23
3300 5/1/23
3800 5/4/23
4200 6/1/23
6000 6/6/23
pitrott1 is offline   Reply With Quote
Old 01-26-2024, 09:29 PM   #20
pitrott1
OSCM(SW) USN Ret.
pitrott1's Avatar
The above to go with this!
1100 3/29/23
2000 3/30/23
3300 5/1/23
3800 5/4/23
4200 6/1/23
6000 6/6/23
Old 01-27-2024, 08:28 AM   #21
Joshinator99
Moderator
AGAIN, that uses the LS thermostat. OP specifically stated he wanted to use the LT style thermostat.
Old 01-27-2024, 10:12 AM   #22
pitrott1
OSCM(SW) USN Ret.
pitrott1's Avatar
Again, 2014-2020 GM, Chevrolet, LT Engine Billet Thermostat Housing w/ 180 Thermostat. Key word LT
1100 3/29/23
2000 3/30/23
3300 5/1/23
3800 5/4/23
4200 6/1/23
6000 6/6/23
Old 01-27-2024, 11:34 AM   #23
Joshinator99
Moderator
THAT IS AN LS THERMOSTAT. Look at an LT thermostat and then look at an LS thermostat, then we can continue the conversation. They’re using a custom thermostat housing to allow the use of LS thermostats on an LT engine since the low temp LT ones are either not available or not reliable. So what you posted is literally the same as every other aftermarket housing…they all use LS thermostats.
Old 01-27-2024, 12:23 PM   #24
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
BTR LT4 thermostat housing $79.00 bucks, $20 more with the T-stat included. It's your money? But for $100-200 less you can save that $ or put it somewhere else.
Revalot is offline   Reply With Quote
Old 01-27-2024, 12:27 PM   #25
Revalot
Sure you can get a more expensive one, but a leave it like so, sand it a little or whatever, but at the end of the day it's under the hood polished with dust, or plastic with dust, or aluminum with dust !
Old 01-27-2024, 06:25 PM   #26
CalgaryZL1
CalgaryZL1's Avatar
That’s the exact one I bought. I just want a spare thermostat on hand after reading that people had problems with them either sticking closed or sticking open?
Old 01-27-2024, 08:14 PM   #27
pitrott1
OSCM(SW) USN Ret.
pitrott1's Avatar
Ditto here, use that as a spare also. It's all about the housing!
1100 3/29/23
2000 3/30/23
3300 5/1/23
3800 5/4/23
4200 6/1/23
6000 6/6/23
Old 01-27-2024, 08:30 PM   #28
CalgaryZL1
CalgaryZL1's Avatar
Thank you!! someone gets my gist of it
