#15 |
![]() Drives: 2018 Camaro SS 1LE Join Date: Oct 2019
Thank you both for the input! I will watch that video
#16 | |||
![]() Drives: 2021 SS 1LE Join Date: Mar 2023
Didn't realize the kit came with a drill bit. I'll check what shape mine are in and pick one up. re: #3 -- which backing washers? I went with the BK kit. There are a couple of very thick black washers that the instructions aren't clear on where they go. I'll toss them in a separate thread with that question.. re: #4 -- I've got the carpet around the driver's seat pulled back - the sound deadening in it is very thick. I don't think I understand what you mean about it not applying for mounts on a seat bracket.. Thanks for the tips! |
#17 | |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Some of the pictures above had the lap belt mounts on the seat brackets. In our install the stock seats were used and the lap belts mounted to the floor board behind the seat. You obviously want large washers to distribute the load, but the floor board isn't completely flat. In order to get it to work we had to grind a 3/8" flat into one side of the washer making more of a "D" shape than a "O" shape. We cut the carpet and pad on the top side where the belt mounting bolts went through. He used a 4-point belt set designed to do that with factory seats.
