#15 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#16 |
You're right, but I will say that it's pretty difficult to pop off that keyhole cover without scraping the clearcoat. Also, replacing it is very tricky, you have to position the cover at a particular angle, otherwise half the retention notches will engage and the others not, which then makes removing and re-seating it even more difficult without damage. So I prefer to avoid having to do this if at all possible.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 12-26-2023 at 08:49 AM. |
#17 |
![]() Drives: 2016 Camaro 2SS "Convertibobble" Join Date: Mar 2022
Inside one of those magnetic keyholders, you mean?
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp) '99 4Runner 367K '94 ST1100 146K Last edited by The Chief (tm); 12-26-2023 at 01:55 PM. Reason: Change |
#18 |
![]() Drives: 2023 Camaro LT-1 Join Date: Jan 2024
Won't start
Fiddle farting around troubleshooting my 2023 LT1 Camaro suddenly not starting when the wife admitted having run BOTH key fobs through the washing machine, but did not run them through the dryer.
Been reading the procedure for reprogramming the key fobs which is similar to arming and launching a submarine launched intercontinental ballistic missile with multiple nuclear re-entry vehicles. Really?
RM1 (SS) Kent C Alexander USN (RET)
Total and Permanant Service - Connected Disabled Vet Last edited by Kent A; 04-03-2024 at 06:33 PM. Reason: Clarity |
#19 |
![]() Drives: 2019 2SS Riverside Blue Join Date: Aug 2011
The “hidden key” is accessible on my FOB without having to open it up.
I use the key to lock my glovebox when I need to. |
#20 | |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
#21 | |
![]() Drives: 2023 Camaro 1SS 1LE 6MT Join Date: Nov 2023
Sounds like the batteries die in about 4ish years, regardless of use |
#22 |
The batteries are about $2 each, here it the game plan, every 2 years change both of them and never have a problem, it comes out to about $2 a year for your $50k car...
#23 |
My suggestion is more towards fobs, getting lost or damaged. The programming of a new fob is a lot easier with the two fobs method compared to only having one fob or no fobs that work.
#24 |
So ideally to reprogram a fob you need two working ones. If one just had a battery replacement would that still work as two functioning ones, or would that one have "lost its programming" after battery removal?
#25 |
![]() Drives: 1974 Z28, 2002 Camaro SS 2024 ZL-1 Join Date: Aug 2008
To me it sounds strange to have to replace batteries in the key fobs after only four years.
I've got three older cars, a 1998 Jeep Grand Cherokee 5.9 LTD, a 2002 Camaro SS, and a 2004 Ram SRT-10 and I've never replaced the batteries in those key fobs and they still work fine. It's possible that they don't have as many features as the newer Camaro so they are used less, but they do have remote lock/unlock, arm alarm features. Also these cars have very low original miles, so I guess the fact that they aren't used constantly also contributes to the long battery life. |
#26 |
#27 | |
https://a.co/d/8d7aLpW |
#28 |
![]() Drives: 2021 3LT RS A10 Join Date: Nov 2021
where's a good place to get replacement fobs, and how much?
