Old 12-22-2023, 01:24 PM   #15
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Good numbers in my opinion and not all Dynjets read higher than Mustangs. There are a whole lot of factors that go into to it. Temps, DA, SAE, Standard on the day of the pulls. I actually talked to Chad this morning and he was telling me that his Zr1 made lots of pulls on a Dynojet before he got his own Mustang Dyno and the numbers were very close to each other so it's not always accurate that the Mustang is stingy in every case. He did drive it on the street also to make sure it was all good and was going to get it on the street again before you pick it up. He was very happy with the results so I know you will be also.
Ya can't wait to pick it up. Thank god next week is a 3 day work week get Friday off so will be flying down there to pick it up and drive it 580ish miles home.
Old 12-23-2023, 04:38 PM   #16
laynlo15
Drives: 2022 Lt1 A10
If all works like it should I'll be picking you up at the airport in St Louis and getting you to Chad's for the pickup of your ride. I know you'll be grinning from ear to ear when you get to drive it. I'd have Chad go out with you for the ride so you can ask him any questions instead of just picking it up and taking off. You want to make sure it shift right and just make sure its all ok before you take off for a 10 hour drive. You probably will have to run 91 or 93 for your first fill up to get you home. I'll buzz you on Tuesday for an update in my plans, we should be good to go, but wait till I contact you to cancel your rental.
Old 12-23-2023, 08:09 PM   #17
FlukeSS
FlukeSS's Avatar
Much appreciated!
Sorry can't do much about the video quality they sent it to me that way:
Old 12-25-2023, 07:26 AM   #18
laynlo15
Man that is one of the worst I've seen. You'll see it in real time, although not on the dyno next Friday. Merry X-Mas.
Old 12-26-2023, 12:53 PM   #19
FlukeSS
FlukeSS's Avatar
lol, I thought so too
Happy new year as well.
Old 12-26-2023, 09:07 PM   #20
LT1gen6
LT1gen6's Avatar
Drives: '22 LT1 Coupe
Originally Posted by FlukeSS View Post
. . can't do much about the video quality. .
It sounds amazing : )
LT1gen6 is offline   Reply With Quote
Old 12-27-2023, 10:26 AM   #21
FlukeSS
FlukeSS's Avatar
Got the damage numbers for the repair and upgrade.
Spun rod Bearing + Cracked Crankshaft
Salvageable block - rebuilt and machined
Stage 1 cam and supporting accessories
TCM unlock and tune
DOD delete
Retune E85
$12,900 total Which is what I was hoping for. I am happy the way it worked out.
Old 12-27-2023, 02:12 PM   #22
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Do you plan on taking down the 1/4?
Glad you're getting it back dude. GL with trip
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 12-29-2023, 10:57 AM   #23
laynlo15
Sounds about right to me.
Old 12-30-2023, 12:22 AM   #24
FlukeSS
FlukeSS's Avatar
So about that... lol. Louder than I anticipated, but love it.
Old 12-30-2023, 12:30 AM   #25
FlukeSS
FlukeSS's Avatar
Ya I plan too, but when it warms up, for now just a daily for work.
Old 12-30-2023, 04:53 AM   #26
Dynamical
Dynamical's Avatar
Dude that sounds bad ass! How’s it drive?
Old 12-30-2023, 12:46 PM   #27
FlukeSS
FlukeSS's Avatar
Runs great at normal driving speeds. Kind of babying it a bit for the first 1500 miles, need to do an oil change then. Guess it has 15w40 break in oil in it now.
Also shop recommends I use 10w40 non synthetic oil on the engine because of it being modified, and rebuilt with a little looser tolerances. They said they tend to see a lot of lifter issues with synthetic oils which is also why they recommend non synthetic, but said there is some synth that can be used with my build if I wanted to stick to synth. I'll have to change the oil every 3000-4000 miles.
I don't care if its synth or not just whatever is best for the engine is my only concern.
