Old 12-16-2023, 10:06 AM   #15
Isn't the ZL1 a bit too porky for autocross and that might be why?
Not trying to diss that car, after all, mine is probably just as heavy now, but people don't tend to choose a 4000-lb powerhouse for autocross where you can't use the extra power at 120+ mph...
Old 12-16-2023, 11:41 AM   #16
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
A lot of people I know have the zl1 or zle to autocross here in SoCal. But we did have a large lot with up to 80 mph at the time. Now just smaller little car lots. Most with staggered larger zle size wheels and tires and camber plates and more camber. But that’s about it.
VR Baron is offline   Reply With Quote
Old 12-18-2023, 03:02 PM   #17
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
Originally Posted by GAGT View Post
Damn, think I could of gotten that 0.287 with the calibration? Next year.
-Erik
Hah You never know
#53 F Street
2025 FS National Champion
2025 Sponsor autocrossdigits.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 01-07-2024, 03:14 PM   #18
clyde
clyde's Avatar
Drives: broken
I got the calibration flashed to my car and wanted to leave something here for anyone that might be searching later.
Whether the dealer service tech is able to apply the calibration for your car is dependent on the person at GM Techline that answers the phone when they call. If the person knows what to do, all should be good and you should be on your way with an updated module within an hour.
If they don’t, they may waste a couple hours trying to figure it out before ultimately giving up. If that happens to you and you’re like a bunch of people I’ve spoken to in the past couple weeks, you might repeat this experience at four or five more dealers before it works out, but you should be able to avoid it.
The way to avoid it is for the dealer service tech to hang up on Techline and call back when the Techline person doesn’t know what to do and then repeat that until someone answers that does know. If it’s going to be a successful call, the service tech should be able to tell pretty quickly. Somehow, you need to get this communicated to the service tech whether you can talk to them directly or the service advisor can convey the message.
It's ridiculous that it works this way, but is what it is.
clyde
Team WTF?!
what are you gonna do? :dunno:
clyde is offline   Reply With Quote
Old 01-07-2024, 03:41 PM   #19
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Anyone selling preprogrammed drop-in modules ?
( 2017-2018 Model Year - Calibration Part Number 84506758 ?)
ing for grip.
http://www.motorsportsne.com/
Old 01-07-2024, 04:18 PM   #20
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Nope. To get the download, a dealer will need your own VIN code. Therefore, it's on a "per car" basis rather than "per module."
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 01-07-2024, 05:19 PM   #21
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
So if I want Autocross calibration for my ZL1 1LE.. i need to find someone with SS 1LE ? Or will GM tech line allow mis-match install ?
ing for grip.
Old 01-07-2024, 05:56 PM   #22
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
I've heard the oem ZLE calibration is pretty close to the autox cal for the SLE, which makes sense since the ZLE comes with R comp tires.
Old 01-08-2024, 02:17 PM   #23
cdrptrks
cdrptrks's Avatar
Do you know if a used ZL1 1LE eDiff module could be installed into an SS 1LE to use that calibration without paying GM for the AutoX tune? I sometimes run 3R tires on track so it would be nice to be able to swap eDiff modules when I swap between SC3 and SC3R tires.
I guess the ZL1 1LE's lack of magride and different gear ratios and different final drive ratio might prevent it from working but I'm no expert on this.
Old 01-08-2024, 03:55 PM   #24
Msquared
Msquared's Avatar
I don't know for sure if a module from a ZLE will work in an SS 1LE. As you noted, there are a lot of differences in the chassis setup, so maybe not.
Matt Miller
2020 SS 1LE
Old 01-08-2024, 04:32 PM   #25
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Is the eLSD controller separate from MagRide? I was always curious to try it out as AutoX calibration since ZLE wants to hang ass our sideways.. while fun, not exactly fast.
ing for grip.
Old 01-08-2024, 05:01 PM   #26
DaveC113
DaveC113's Avatar
No idea... it might work but it might also be risky to try it.
Old 01-08-2024, 05:30 PM   #27
DaveC113
DaveC113's Avatar
It is a different module.
Old 01-08-2024, 05:57 PM   #28
Msquared
Msquared's Avatar
Yes, it's the small Chassis Control Module on the floor of the trunk just behind the fuse box and to the right of the emergency tire kit. All Camaros (and a whole bunch of other GM vehicles) have this CCM, but only those with Magride have the Magride module on the left side of the trunk floor.
Matt Miller
2020 SS 1LE
