Old 11-29-2023, 07:56 PM   #15
Coded4SS
Drives: 23 Zl1
Originally Posted by Redmoe View Post
Mine looks similar with 2300 miles
Ty for this! Makes me feel lil better
Coded4SS is offline   Reply With Quote
Old 11-29-2023, 08:10 PM   #16
Redmoe
Drives: 2022 Vivid Orange ZL1 Vert M6
I added some more details in that post, I think our coolant losses are similar. Mine seem to be slightly less but I have not tracked the car so that could make up the difference.
Redmoe is offline   Reply With Quote
Old 11-30-2023, 07:25 PM   #17
Redmoe
This doesn’t cover our model years but could be the issue: https://static.nhtsa.gov/odi/tsbs/20...09122-0001.pdf
Old 11-30-2023, 08:40 PM   #18
triggerjerk
Drives: 2023 Camaro ZL1
I have no coolant loss but the bottom corners of my hx also has grimey build up.
I am wondering if they naturally weep from the bottom and attract dirt? 1700 miles.
triggerjerk is offline   Reply With Quote
Old 11-30-2023, 10:13 PM   #19
Redmoe
Do you know if your lower overflow is at the mid point line when cold? Just curious if they are filling them to the line from factory.
Old 11-30-2023, 10:53 PM   #20
triggerjerk
Actually, I just looked. The lower tank is well below the cold fill line.
Old 11-30-2023, 10:59 PM   #21
taylorforschool@gmail.com
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
I just had my entire cooling system drain and filled at a pro shop and this is the case with mine as well. No harm no foul. It’s even an aftermarket system now. Just a little top off. Usually a seasonal thing I’ve noticed when it gets colder. Probably evaporation of sorts
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
Old 11-30-2023, 11:02 PM   #22
Redmoe
I think these have a fair amount of evaporation since the lower overflow is not sealed. Even the manual states something along those lines.
OP maybe the ZL1 has more noticeable loss than your previous V8 due to the added heat of forced induction? Please update us when you get it back from the dealer.
Old 11-30-2023, 11:06 PM   #23
triggerjerk
That is what I am thinking.
Can fluid be added directly to the lower chamber (if the top is full) without having to open the top cap as well and run the engine per the manual?
Old 11-30-2023, 11:45 PM   #24
Redmoe
When cold you can fill the lower tank via the little tube behind the main cap. The manual says to fill bottom to approximately half way, top should be all the way to the filler neck.
Old 12-01-2023, 04:10 AM   #25
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
The lower tank has vent holes in it, which contributes to evaporation over time.
Old 12-01-2023, 05:07 AM   #26
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
...and why you may smell a bit of coolant smell underhood especially after running it hard.
RUQWIKR is offline   Reply With Quote
Old 12-01-2023, 08:13 AM   #27
Redmoe
Great information, thanks everyone!
Old 12-01-2023, 11:03 AM   #28
Coded4SS
Drives: 23 Zl1
Ah this is some good info. I appreciate it all i never seen those holes. But how much evaporation is normal? Id think this would evap the same as my SS. Granted these cars do get pretty hot in the engine bay. So zl1 owners how much coolant do you normally go through?
I followed up with the dealer and waiting for their response today.
