11-06-2023, 06:28 AM | #15 | |
Shadow Gray '19 ZLE M6
https://www.camaro6.com/forums/showthread.php?t=617951 https://www.camaro6.com/forums/showthread.php?t=596237
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
11-06-2023, 07:50 AM | #16 | |
2016 NFG 1SS A8
11-06-2023, 08:31 AM | #17 | |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
The changes you need to make:
The only options that beat this combo are true racing brakes, because the factory caliper just isn't as capable as a racing caliper. I had zero issues stopping my 1000HP ZL1 from speeds, I used OEM rotors with pagid endurance pads. |
11-06-2023, 01:35 PM | #18 | |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
With all that being said, those 15.5" rotors are as good as it gets. I feel that what you gain in cooling by going to a small after market rotor due to slotting, you lose in outright stopping power. If I were a guessing man I'd say to keep the OEM rotors and go to an aftermarket pad that offers more initial bite along with better brake fluid. |
11-06-2023, 01:36 PM | #19 |
11-06-2023, 02:41 PM | #20 |
Drives: ‘23 ZL1-1LE Join Date: Mar 2023
The copper free brakes use a larger rotor, coupled with the correct pads (if available) may help. You may break ground in that department. I could be wrong but I believe they are the same size as the Blackwing units (same platform). Don’t know if the calipers, mounts etc. are different than the standard ZL1 units.
11-06-2023, 03:22 PM | #21 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
I run GLOC street pads on the street, and then G12's on the front and G10's out back for track days. G18's are for serious REALLY high speed endurance racing and will mostly eat your stock rotors faster than you'd think. But these pads are a HUGE difference compared to the street pads on track and are extremely consistent and able to deal with plenty of abuse.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
11-06-2023, 03:32 PM | #22 |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
I see they are not recommended for street use. Is that actually true though?
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
11-06-2023, 07:07 PM | #23 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
You could go R16 up front and R12 out back instead. You can just swap them out with the stock pads when you're not racing. Literally takes maybe 20 minutes to do in your garage or driveway. You can also try Hawk DTC 70 (front) and 60 (rear). |
11-07-2023, 08:37 PM | #24 |
Main reasons for this are they don't really work until they're up to temperature, and they are EXTREMELY noisy, think about what an old school bus sounds like and multiply that times 10.
Old: 2017 SS 1LE
11-18-2023, 06:59 PM | #25 |
Drives: 2017 ZL1 Join Date: Aug 2020
Lots of great suggestions. If the above is who I think it is I visited with ur dad at optima when u had to bug out quickly. Was hoping to visit with you as well.
I’ve been by ur house when I first got the car several years ago and you gave me some tips and I run the g loc pads you suggested for street and track. Ur car was my fave at Vegas. Currently have had an old injury flare up that may sideline me for a bit so car stuff currently on hold. Thanks for all the great suggestions folks! |
11-20-2023, 09:36 AM | #26 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
How do the R18 compare to the R16? Based off of what I can find online, R18 is more aggressive than DTC 70. I was thinking of trying R16, which is supposed to mimic DTC 70s, but not sure if it would be inadequate on slicks.
11-20-2023, 12:06 PM | #27 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Do you know what your brake rotor temps are?
Do you know what your brake caliper temps are? You need to know what that is before you start throwing parts at an issue like this because it will help you direct your funds in the right place. Not to sound in a way talking down to you (because I don't know you/your level of knowledge, so sorry), but it may even be down to a "driver mod" in how and where you are braking on track. I only say this because of the mention of the prior C5 car that is significantly less in weight, but also not as fast in the straights (into a corner). |
12-10-2023, 05:41 AM | #28 |
Drives: 2018 ZL1 A10 Join Date: Nov 2020
High temp fluid - stainless lines to replace the rubber - hawk pads 7s all around - helped me ALOT - still heat up but only a smaller softer red glow. No brake fade at all. But im only 750 at the wheels
