10-30-2023, 07:39 AM | #15 |
You can plug it in under the hood or in the trunk directly to the battery. Under the hood is the easiest and most logical as it doesn't require removing panel clips nor pulling back the liner to access the positive terminal on the battery.
2016 NFG 1SS A8
10-30-2023, 09:45 AM | #16 |
Drives: ZLE/DEMON/GLADIATOR/GSXR1000R/ZX10R Join Date: Aug 2022
I connect the tender directly to the terminals under the hood of my ZLE for the entire winter.
ZERO issues.
2018 Dodge Demon #1399 2020 Jeep Gladiator Rubicon 6 speed manual 2023 ZL1 1LE 6 speed manual ************************* 2018 Suzuki GSXR 1000R 2021 Kawasaki ZX10R |
10-30-2023, 12:49 PM | #17 | |
Drives: 2024 ZL1 M6, 1969 Cessna Skylane Join Date: Jun 2018
If I were hooking up such a charger to my car, I'd do it through the front just out of convenience. The cables involved are made to carry hundreds of amps so I'd guess any effect with a charger is going to be minimal. My cars get driven year round so it's not something I have to deal with. Just pointing out why a mechanic might advise to hook up directly to the battery. |
10-30-2023, 01:34 PM | #18 |
I have a battery tender that came with a connector in the middle of the charging cable, similar to what Calgary posted above. I have the cable hanging outside of the access "port" in the liner, so when I need to charge, I just plug in the cable and it's ready to go.
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
11-03-2023, 05:59 PM | #19 | |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
I was just looking at getting an extra set of these, I see how it will connect to the Under hood Positive, is the eyelet big enough for the Neg stud underwood also? I think I'll route the connector to the bottom of the car so I don't need to pop the hood everytime
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
11-04-2023, 11:06 AM | #20 | |
Drives: 23 ZL1 20 Jeep GC Join Date: Aug 2020
I was also going to run it through the bottom until I saw a post on here that there is a small space by the headlight that works perfect. I ran it through there and it tucks in right between the air inlet and grill.
23 ZL1-A10-Summit White
11-04-2023, 11:25 AM | #21 |
I had no luck charging from under-hood locations. I thought it was charging but it wasn't. I now charge in the trunk using the pos/neg leads that come with my trickle charger.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
11-04-2023, 01:06 PM | #22 | |
11-05-2023, 08:48 PM | #23 |
11-06-2023, 07:16 PM | #24 |
Drives: Chevy Camaro ZL1 1LE Join Date: Aug 2023
I want to use a trickle charger this winter. I purchased a NOCO Genius 1 charger. It has a 12v mode and an "AGM" mode. Evidently, AGM batteries run at a higher charge. NOCO Support says the 12v mode charges to 14.5v and the AGM mode to 14.8v. Does anyone know what what kind of battery we have? It is supposed to be on the label, but my car is already in storage an hour away or I would just look.
11-06-2023, 07:32 PM | #25 | |
11-06-2023, 09:11 PM | #26 | |
11-07-2023, 06:38 PM | #27 |
Just finished my install.
11-09-2023, 12:34 PM | #28 |
376 cubic inches of fun
I've always used the under the hood terminals, for 13 years on my 2010 SS and now on my replacement, a 2023 ZL1. There is absolutely no problem doing this.
I use a Battery Tender, which is a smart charger that regulates voltage and current to keep the battery charged but not overcharged during long term storage. I don't think any voltage drop from the remote connection is even a factor for this type of charging. If a connection is inadequate, the device will warn you with simultaneously blinking red and green lights. The Gen6 positive under the hood post is a bit small for my liking (compared to the Gen5) but everything is working, so no worries. |
