Old 10-17-2023, 11:17 AM   #15
clg82
Drives: 2020 Camaro ZL1
I was thinking of getting rid of the DSX low side (and plugging the tank where the DSX low side feed was added) and run Katech's in-tank pumps. Even though I would never really use the car for a road course/auto-X/etc, I like having all the functionality GM engineered into the system. I don't want to have to worry about fuel sloshing around below a 1/2-1/3 tank and all that.
Looking forward to whatever you post here
How about enjoying some of the GM engineered functionality in the rest of the car on a road course
Old 10-17-2023, 12:25 PM   #16
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Originally Posted by Megahurtz View Post
Also, a little birdy told me DSX is working on a complete package that includes an intake low side solution and port injection that integrates with HPTuners to allow the stock ECU to control the port injectors. I have no proof or special knowledge of this, but if true, it's going to be awesome.
I think Dave himself posted that this is in the works on facebook or one of the forums. That would be the ultimate solution, for sure. I assume there would be a segment addition to the ECU through HPT, possibly a segment that comes from a C7 ZR1 or something similar.
Mods being installed-
Old 10-17-2023, 12:32 PM   #17
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by Rapid_blue_zl1_22 View Post
Gotcha. I definitely think this is the better solution. I was considering the DSX low side, but I just did not want to drill my tank. Plus, I do track my car, so it wasn't a good option anyway.
I didn't want to, but I didn't have another option that would work for my situation. TravisLambert had issues with his DSX, just because of the fuel sloshing from one side to the other, and I don't remember how he fixed that, but this configuration is perfect for what I believe I need. I'll fix that in the future with this
At least it looks like I can reuse the DSX controller, and just correct the plumbing, as necessary. I'm hoping you'll post some information about that, too, if you have the time.
Yeah - IF I had a course that was close. My nearest track (10-minutes away) is closing, and Sonoma is about an hour away, when there isn't traffic, so... But I want to!
'20 ZL1 Black "Fury"
Old 10-17-2023, 12:46 PM   #18
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
What did you want to know about the controller? I already have that installed. All I had to do to make it work was extend the 2 wires that connect to the DSX aux pump itself. The rest of the kit is installed the same as the DSX kit.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 10-17-2023, 01:29 PM   #19
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
OK. I think that's enough information for me to understand.
If I already have a low-side kit installed, do you think I'd have to create a completely new low side, or do you think I can get away with using the DSX, and integrate the secondary Katech pump into the existing DSX system? I'm sure I'd have to move some stuff around, but I hear my fuel system (DSX/THPSI) is good to around 1000-WHP on E', and that's all I'm trying to build up to (because I'll never want to go that high, and don't want to have to add a separate secondary fuel line up to the engine unless I have to). So - do you think I can "T"-into the OEM fuel supply line, like the DSX does, with Katech's pump kit, or do I have to run a completely separate line, from the secondary pump, up to the rail area?
Old 10-17-2023, 01:41 PM   #20
Rapid_blue_zl1_22
No, for the plumbing side, you would just remove the DSX system and put the lines back to stock. The Katech pump uses the factory fuel line for both pumps. All you have to add is an inline fuel filter.
Old 10-17-2023, 01:57 PM   #21
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
Yeah there is going to need to be a special write requirement at first before this would be possible. But if the ECU has the room, it should be possible to add the ZR1's port control functionality.
Old 10-17-2023, 02:05 PM   #22
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
what kind of power are you looking to make? i need something that will hold 1000 rwhp on E.
2018 Camaro SS A8 Edelbrock 2650 FBO 93 octane 9.54@144 Pump E 9.12@156
2010 Camaro
Stock bottom end with 46,000+miles JRE remote tuning Whipple A6 and Drive it to and from the track 9.46@146
94guy is offline   Reply With Quote
Old 10-17-2023, 02:52 PM   #23
Rapid_blue_zl1_22
Katech claims this pump will support 1000whp on full E85. You will just have to have the high side or port injection to go along with it.
Old 10-17-2023, 03:52 PM   #24
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
This is a game changer and I’ve been in contact with Dave about this. Supposedly ready by end of year…but…all manufacturers say that stuff lol…. Worth the wait though.
Old 10-17-2023, 04:23 PM   #25
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Yeah I'm definitely excited about it. We have a couple of cars that will be ready to install the day it releases. I'm likely going to hold off on some of the mods on my new 2023 ZL1 so that I can wait for an all in one fuel solution.
Old 10-17-2023, 04:31 PM   #26
Joshinator99
Moderator
Yeah you can add me to that list. My new Whipple 3.0 has been installed for about a whopping 5 months and it’s coming off and getting shipped to Katech for the port injection modification (comes with injector ports and rail retaining bosses precast from Whipple) the minute my car is parked for the winter. That way it’ll be ready to rock. Already have the Fore triple with -10 AN supply and -8 AN return lines so all set there.
(Sorry, didn’t mean to derail the thread….!)
Old 10-18-2023, 08:00 AM   #27
Katech_Mike
Drives: 2015 Camaro ZL1
If you already have a DSX low side system, there shouldn't be any need for this. Unless you are replacing the DSX system with this for low fuel functionality, but then you would have to buy a new fuel tank.
You would simply install a bulkhead fitting and use an AN cap to plug it. About $25 in parts to seal a preexisting aux pump hole.
Katech_Mike is offline   Reply With Quote
Old 10-18-2023, 10:33 AM   #28
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
FOR CEREAL?! EXCELLENT!!!
Thanks for everyone's information!!!
