Old 10-23-2023, 07:49 AM   #15
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
JB Weld, that'll hold it...
Old 10-23-2023, 09:59 AM   #16
ctrlz
I was thinking the same thing. Don't have many threads saying, "The JB weld didn't work!"
Nice job, GlennB!
Old 10-23-2023, 11:13 AM   #17
driftking123
driftking123's Avatar
Drives: 2022 SS 1LE
Originally Posted by GlennB12 View Post
Upon doing a leak check on the exhaust I did indeed find a hole! I put high heat JB weld on the hole (says it can withstand 1000 degrees, and is made for exhausts) it takes 24 hours to cure so just waiting on that and will update when I clear the code to see if it comes back.
Just curious, where was the hole and how did that happen?
driftking123 is offline   Reply With Quote
Old 10-31-2023, 11:23 AM   #18
Nachos17
Drives: 2016 Camaro 2SS A8
I'm also curious where you found the hole? I have the same code on my 2016.
Nachos17 is offline   Reply With Quote
Old 03-08-2024, 04:43 PM   #19
RotoRocker
Drives: 2019 2SS 1LE
Curious as well
RotoRocker is offline   Reply With Quote
Old 03-10-2024, 12:52 AM   #20
MyNameIs
Drives: Camaro SS
Hello,
I got a P0430 code on my 2021 LT1.
Says I should replace the catalytic converter.
If I purchase a new catalytic converter from GM, would I have to tune the car? I saw somewhere online that some cars need a tune after a cat replacement and wasn’t sure if I could just replace and break it in and drive normally. Just got the car and only have about 16k miles on it.
I have ordered a O2 sensor, but I am going to swap the stock sensors to trouble shoot and see if the code goes to the bank 1 side to see if possibly the sensor went bad. Still new to this stuff so forgive me if I sound amateur about this. Just trying to get some advice on how to get rid of this engine code before emissions.
Any input would be greatly appreciated!
Thank you.
Pretty sure a 2021 CC is still covered by warranty. Emmissions warranty surpasses standard warranty.
MyNameIs is offline   Reply With Quote
catalytic converter, exhuast, lt1 6.2l engine
