#15 |
![]() Drives: LT1 Join Date: Mar 2022
> Twice already I ground second.
> I have to make a mental note to put more force on the shifter and know it's fully at its stop Just a question, are you trying to force it through the 1-4 skip shift gate? |
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Baby Blue
#17 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
I would put this trans up against the best. It’s really that good.
#18 | |
![]() Drives: 2023 ZL1 M6, 2010 SS M6 Join Date: Oct 2009
Just a youtube-uploaded phone-cam of you smacking it around 1-2-3-4 (with the car safely stopped/level/parking brake on) from the left hand side high with your hand and forearm to the right of the stick would show what you're talking about. |
#19 |
![]() ![]() Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
I test drove a 1LE with the factory short throw shifter.
I thought was great for an OE unit |
#20 |
OSCM(SW) USN Ret.
Drives: 2023 Camaro 2SS-1LE VOM 6M Join Date: Apr 2023
My M6 does one thing great, my wife can't drive stick. As for the skip shift, I learned from my 95 Z28 when it shows the skip shift message, I just hold the clutch in a few seconds more and it times out that minor annoyance.
2023 2SS-1LE VOM, 6M, SR S-TBrace, A-PDL's, Fuzzy suede KP's, NAV
1100 3/29/23 2000 3/30/23 3300 5/1/23 3800 5/4/23 4200 6/1/23 6000 6/6/23 |
#21 | |
These cars are for fun, don't endure something so noxious that's so easily fixed. As a pragmatic matter, those few seconds on the clutch aren't funny on a long left turn across incoming traffic, and your revs are dropping under where 2nd wants to be. There are choices of car color, or auto vs manual, or Ford vs GM, that are really just a matter of taste between great options. Leaving skipshift there is not one of them. |
#22 | |
OSCM(SW) USN Ret.
#23 |
![]() Drives: 2017 Camaro SS Join Date: Jan 2018
I have the Hurst short throw shifter that uses the stock shift knob I feel like it removed a lot of the slop in the shifter the throw is much shorter it does have some notchiness to it I ran that setup for a couple years now i wanted to see if I could remove the notchiness out so this year I added a Raceseng ashiko weighted shift knob and adapter it’s the heaviest one they make it removed all the notchiness out and falls into gear with little effort wish I would’ve done the shift knob sooner
#24 |
![]() Drives: 2023 1SS 6 speed Join Date: Aug 2023
No. Both times I was actually down shifting due to slowing traffic.
#25 |
I liked the direct feel of the T56, and the shifter was directly connected to the shift rails. not thru some plastic bushings.
#26 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS, 2010 Camaro SS Join Date: Apr 2012
The Hurst Shifter is a great option.
#27 |
wow, really surprised by some comments.
1) agree the red line and the Hurst shifter = probably the best feeling and shifting trans ever made at a 650 lbs torque rating. 2) F86 twins, sorry you feel that way, the AX15 trans same on Silvia and Miata NC is one of the best transmissions made stone stock. 3) come now a rabbit 4 speed was absolute slop compared to the Honda trans. 4) each car needs to learn and break in. I'd practice a whole lot more.
#28 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
If you get skip shift to engage you deserve all the pain you get for driving like you do.
