#15 |
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2019
1/3 tank. If I plug my time into one of those DA correction calculators it says my corrected time is 11.6@121. idk how much I believe that, but what trap speed would you expect for my car?
2018 1SS 1LE - DSX E85 Kit | Full ARH Exhaust | RotoFab CAI | Katech Cam | Katech Ported Stock Heads | Tuned - 530HP/456TQ
#16 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
Well, first of all you are about 70 lbs lighter with only a 1/3 of tank of gas or about 120 lbs lighter with a drag pack than your curb weight. That alone is worth a tenth and 1 mph . With 462 rear wheel horse and 469 torque and lets say in 600 to 1000 DA I would expect a trap speed in the 122 mph range.
#17 | |
#18 | |
I have no headers, all cats and mid pipe in place, a borla touring axle back only , stock air box, and a LT2 intake. You are where I should be with headers and high flow cats. Your ARH system uses its own mid pipe and cat set up right? |
#19 | |
https://americanracingheaders.com/co...stem-quad-tips
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i would guess all you need is some seat time to run the car to its potential. shifting is everything in an m6 car and is frequently reflected by the trap speed. that car would easily be 2 mph slower on the stock wheels, putting you around 116 mph. which in my opinion is hardly faster than a stock one. mine went 115 when it was completely stock in 2600' da.
i never raced my car at the dragstrip on the factory wheels, but i made some dragy hits just for something to do. 4 things to consider: the car made 441 whp at this time, was 2 mph faster on those drag wheels you are using, i had a 175 lb passenger in the car and the da was a lot closer to 3000'. mid july in central indiana is terrible. the car always picked up 26+ mph on the back half. i frequently saw 27+ on those race stars. my opinion: your car should be 120+ mph as it sat. hard to say if it's in the tune, driving, or both. et ultimately tbd by 60'.
