Old 09-21-2023, 10:29 AM   #15
Z OH 6
Drives: 2024 CT5-V Blackwing
Originally Posted by RamAir02 View Post
So what's funny is the ARH guys are largely former Kooks guys. Kooks used to be based in Long Island. They moved down to North Carolina. Folks who remained in the northeast started ARH. ARH products are manufactured in the old Kooks building and on old Kooks equipment.
Interesting fun fact, wasn't aware of that.
Old 09-21-2023, 11:10 AM   #16
Drnick
Drives: 22’ ZL1
Actually ARH was, or is right next door to
Dr.Corvette on Long Island
Drnick is offline   Reply With Quote
Old 09-21-2023, 12:12 PM   #17
2023ZL1
BLACK 2019 ZL1
2023ZL1's Avatar
Drives: 2007 COBALT, 2019 CAMARO ZL1
CSP ARE THE EASIEST TO INSTALL AND WERE DESIGNED TO NOT HAVE ANY OF THE ISSUES THAT MAY ARISE ON 2" ARH / KOOKS / STAINLESS WORKS.
CSP HEADERS ARE MADE MY STAINLESS WORKS BUT ARE NOT THE SAME AS WHAT STAINLESS WORKS SELLS.
THERE IS A YOUTUBE VIDEO THAT SHOWS JUST HOW QUICK THEY SLIDE INTO PLACE.
I'M RUNNING A CATLESS SET UP WITH MBRP'S RACE CATBACK (NO MUFFLERS ONLY J-PIPE RESONATORS) CAR HAS A ROTOFAB INTAKE, IT WAS TUNED WITH HP TUNERS AND PICKED UP 55 RWHP OVER STOCK ON A MUSTANG DYNO.
I WOULD HIGHLY RECOMMEND STAGE8 LOCKING HARDWARE.
2023ZL1 is offline   Reply With Quote
Old 09-21-2023, 12:35 PM   #18
Drnick
Drives: 22’ ZL1
So what exactly is the difference between CSP & Stainless Works
Specifically in regards to the newer Gen ZL1???
Old 09-21-2023, 12:38 PM   #19
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
CSP was designed by Andrew in conjunction with SW as a private label for CSP, specifically designed to be better fitting. SW still sells their original design, too, but I believe it is similar to ARH/Kooks/ etc., where it is not as easy to just drop in.
Mods being installed-
Old 09-21-2023, 01:00 PM   #20
2023ZL1
BLACK 2019 ZL1
2023ZL1's Avatar
ANDREW'S DESIGN FOR HIS 2" HEADERS DOESN'T REST ON THE MOTOR MOUNTS, TOUCH PLUG WIRES OR TOUCH THE STEERING SHAFT AT ALL. I BELIEVE 1 7/8 HEADERS DONT REALLY RUN INTO THESE ISSUES AT ALL BUT THE 2" HEADERS DO.
I'M EXTREMELY HAPPY WITH MY PURCHASE.
I DID LOSE 2-2.5 LBS OF BOOST WHEN I WENT CATLESS HEADERS BECAUSE I DIDN'T CHANGE THE LOWER PULLEY, THE CAR IS MORE EFFICIENT NOW BUT EVENTUALLY I WILL BE DOING THE SWAP.
Old 09-21-2023, 01:01 PM   #21
Nataphen
Drives: None
CSP has switched to Kooks as their builder for their private label. They’re built to connect to the stock mid pipe for those who want headers only, they clear stock plug wires, and they’re easier to slide in, so you shouldn’t have to jack up the engine even with stock engine mounts. I just picked up a set myself since those perks were exactly what I was after.
Nataphen is offline   Reply With Quote
