Old 09-15-2023, 01:17 PM   #15
Originally Posted by Bangkok_ZL1 View Post
I did find and already purchased some. They were cheap. Also, I found a nice tip for my JMS Powermax. This guy made a voltage gauge for his JMS so he could Fine tune it and ensure it's always boosting correctly.
I have Space for 2 gauges. and I'm absolutely going to add this to the pod along with my banks i-dash. I actually got a RHD defroster vent dual pod. I can't believe somebody made them.
Nice, progress Thank you for the video, too
Old 09-15-2023, 08:58 PM   #16
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
[QUOTE=2023_ZL1-AUTO;11359523]Good idea, I did the same with a LED voltage meter and just mounted it using 3M double sided trim tape by the OBD2 port, but I can see it while driving just by quickly looking down. I used the grey and black wires used for the vacuum sensor that run from the JMS unit to the throttle peddle since I'm using the peddle to engage voltage boost. This gave me the extra wires to use to carry the voltage from the trunk connection to the LED voltage meter. I explain on my posts I linked above. Make sure you get gauge that can show your voltage to at least 2 decimals. Since you have to set your voltage to 17.47v and not 17.4v[QUOTE]
Actually, I bought a stylish looking 52mm gauge that fits in my pod. It's only 1 decimal place. There was no 52mm voltmeters that were LED. It was really hard to find this one. So I will also purchase the square LED type, which are super plentiful. They are so cheap here, like under $5. I will buy one for setting purchases and keep the stylish 52mm one just to monitor the line while driving to make sure I don't have some catastrophic failure without knowing. I have read that this line is on all the time. If I'm not misunderstanding what I read and it is on ALL of the time, I will toggle switch the line so I can shut the monitor off.
Bangkok_ZL1 is offline   Reply With Quote
Old 09-15-2023, 09:04 PM   #17
Bangkok_ZL1
By the way, Thanks for the idea of using the black and grey wires. This is a good idea. Also, how do you like your Banks I-Dash? That's what is going into the other pod.
Old 09-16-2023, 06:34 AM   #18
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
I love my Bank I-Dash !!! It data logs also!!! I have the super gauge and the data monster. But when I had to start using the AFR gauge I took out the super gauge, but I'm looking for an a-pillar with 3 gauge mounts that has the same look as the stock a-pillar. Once I do, I'll reinstall the Super Gauge
This is the video I used to help get mine installed:
https://youtu.be/9-QDneCUzL8
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
Old 09-16-2023, 12:15 PM   #19
Bangkok_ZL1
Awesome
