09-13-2023, 10:35 AM | #15 |
Drives: 2011 RS 2LT Join Date: Dec 2020
So the Auto and Stick Shift would be the same and work on a V6?
Very good info. Thanks |
09-13-2023, 12:07 PM | #16 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
I am not sure if there are clearance problems within the tunnel where resonator sits but in theory it should, since the pipes are a bit smaller there would probably need to be some kind of adapter as mentioned earlier, which is probably why the dealership didn't want to touch it, but a decent exhaust shop should be able to weld something up pretty easy I'd wager.
Behind every scratch is a story on what not to do, and my car has a lot of stories.
09-15-2023, 10:16 AM | #17 | |
09-15-2023, 05:16 PM | #18 |
OP, gina_09.. Here is some info I dug up as to whether a V8 exhaust and it's components will fit on your V6.. I concluded the answer is yes it will.
https://www.camaro5.com/forums/showt...=168584&page=2
09-16-2023, 08:54 AM | #19 |
OK all, I finally found the diagrams I was looking for to compare the stock systems between the V6 and the V8. Looks like I was incorrect about the resonators. The V6 auto system looks just like the LS3/V8 system. Except from the manifolds and cat pipes.
https://www.camaro5.com/forums/showthread.php?t=35375
09-16-2023, 04:38 PM | #20 | |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
differences are 2.25 Inch system vs 2.5 inch System The Mufflers are not he Same, the SS LS3 muffler is Straight thru, whereas the V6 and SS L99 Mufflers have a helmholtz resonator built in for Frequencies The V8 being a Displacement on Demand (8-6-4) Drone And the V6 Well being a V6 (sound Like poop) Drone But an upgrade on the The V6 is the L99 Exhaust System, Bigger Pypes
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
09-16-2023, 07:01 PM | #21 | |
09-17-2023, 08:57 AM | #22 |
And for you curious folks who like to see the difference in the muffler internal configurations, dug these up.
First one is the L99 Resonator, second is the V6 muffler, then the L99 muffler, last is the LS3 muffler.
09-17-2023, 09:23 AM | #23 | |
It don’t come easy.
Like you say, “for you curious folks”.
10-04-2023, 12:49 PM | #24 |
Great pics. Good info.
Thank you very helpful. |
10-08-2023, 12:05 PM | #25 |
Very welcome! I help whenever I can..
