#15 |
![]() Drives: '16 2SS M6 Join Date: Aug 2019
Mark the location of the bolt head to the intake, so that you can tell if it has backed off. If it hasn't moved since the last time you touched it and it still loosens up then the plastic is deforming or the threaded inserts are slowly pulling through the plastic.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
#16 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
#17 |
Last word- I've never had another moments trouble with the MSD and mounted a un-ported 95mm TB in front with a Soler Performance 95-103 adaptor to merge the two. Car runs like a scalded dog and idles like a Singer sewing machine. Good luck!
#18 |
![]() Drives: 17 krypton green 1le Join Date: Feb 2017
I’ve been on a 5 yr nightmare journey with my car and my hci install; basically have decided my car hates me but the msd has been part of the equation. It’s absolute crap and I have random vacuum leaks I’m pretty sure. It is warped because one of the perimeter bolts you can spin the washer after a heat cycle or two but it still shows correct torque. Previously I have smoked it and didn’t see any leaks but sometimes it seems to seal fine. Took it part anyways and bought new gasket and added rtv. Ran really good for first couple logs now running bad again. Lean at idle to 2k. Boggy down low and some rev hang. Found several perimeter bolts under torque spec and a couple manifold to head bolts. It does not look square against the intake ports when you look at the number two runner you can see from the front as in the inside has more space. Noticed I have oil on intake side of head again too. Going to make a post about that soon.
#19 | |
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
#20 |
I’m considering doing a ported lt2. If that would have been an option way back when I started that’s what I would have done to begin with. Hard to spend another 800$ or so when I’ve got 1700+ in the msd. I’m shifting 7k so I don’t know that I’d miss to much with lt2.
#21 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
might i suggest investing in a smoke machine. i think technical term is automotive smoke leak detector. like this
https://www.amazon.com/gp/aw/d/B07QW...8-0e7e7d413af0 will tell you everything you need to know about potential vacuum leaks. takes <5 minutes to use. with that being said, i've used 2 different msd manifolds spanning several years and thousands of miles. countless pulls in a 125+ mph car. 0 issues. i am not a fan of holleys quality control but i never had any vacuum leaks. also if one is using a 95 mm tb & adapter, the adapter pushed the rotofab tube out enough to contact the fan cage on my car. nothing i did would position it correctly.
#22 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
I’ve heard of folks sealing the top to the bottom with rtv. That’s what I would do the next time I run the msd.
If youre heads cam, I would try to keep the msd. As you see There’s been quite a few folks successful in sealing it. Maybe some are easier to seal than others but rtv will remove all doubt
#23 |
The little smokers work well, mine did not show a leak that I could see but again I’m not sure mine is constant. I believe mine to be sealed at perimeter but may be leaking at runners themselves from being warped. A perimeter leak would almost definitely be easy to spot with smoke. I actually did rtv it when I had it apart last time. Plus I’m not positive I could see smoke if it was coming from underneath as I still had the intake elbow on. I have the adapter a soler one I believe and I had to use a file on fan shroud to get it to clear correctly.
#24 |
Did you try new runner gaskets that seal to the head?
#25 |
#26 |
![]() Drives: 2017 Camaro ss Join Date: Jun 2020
I wonder if it has anything to do with being ported or not being ported. Does modifying the manifold change the way the plastic reacts when in upper temperatures? I did end up buying a snap on torque wrench and I will let you know if there is any difference with the bolts loosening up. I really am considering the BTR manifold as an option. I really have no interest in cutting my hood for a high ram.
#27 |
Well since most or all custom porting is done by hand - not CNC, there's always a chance someone could have a late night or get distracted and we are talking about grinding on pretty soft plastic.
I don't see a guy trashing a $1,200-$1,500 MSD because he had a little slip... but it could happen, and maybe he/she hoped it would be OK. ![]() But I dunno and I'm not casting aspersions on anyone. I am hoping your new torque wrench will cure the issue! |
#28 |
Been a little bit but quick update. I did buy a snap on torque wrench. I comes with paperwork on each individual torque wrench being tested for accuracy, so I think I am good in regards to accuracy. I applied orange locktight to each bolt. Orange is supposed to be an upgrade from blue and torqued all bolts following the instruction. Went for 30-40 minute drive and all bolts are needing retightened. One thing I forgot to do was mark them to see if the bolts are backing out, or is the gasket compressing. At this point I’m either going high ram or BTR because either way I’m tired off messing with this intake.
