Old 09-08-2023, 01:13 AM   #15
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Yep that is correct. Now the Perma codes won't trip the CEL, they are just stored in the background. So, if your state hooks up to the OBD2 then you will have issues.
You can also have it remote tuned. Buy HPt,install a AEM 30-0334 wideband, and hit up someone for remote tuning services. There are a few great options out there for this.
This tune/code info changes things a bit, maybe. my state doesn't inspect for anything so even if I let the ECU cycle, the tune can clear the code from triggering the CEL and the permanent codes won't hurt anything if tune properly?
Any suggestion on what equipment to buy from HPTuner for mail or remote tuning? I would be interested in doing this. I have seen in the past there mail in tuners won't do SC engine.
Old 09-08-2023, 05:59 AM   #16
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
HpTuners.com and this: https://www.hptuners.com/mpvi3/
You will need licenses for the ECU, I believe it's (4) for a 2017 - 2023 and then a laptop and a USB C one the HPTuners end and then the USB your laptop has (B) (C) etc.
Katech Track Day CAM 38%•BTR Dual Valve Springs•Johnson Lifters•Trend 3/8 Chromoly Pushrods• VVT Del•CNC Heads•AFM Delete• C5-R Timing Chain•Katech Oil Pump•Katech 112mm•Maggie 2650 3.25” Upper/ATI SD w/10.32” +20%•10 Rib Belt•RFBG•FI IC Stage 2•THPSI Port w/875cc Inj•Katech Dual Fuel Pump•DSX Aux Pump•SW 2" Headers w/Legend NPP•GESI UHO 4.5" CATs•Brisk RR14S Plugs•BMR Motor Mounts•BMR Cradle Lockout &Bushings Kit•BMR Rear Suspension & 15" Conversion•DSS 1pc DS•RPM 6-Point Roll Cage•10lb FireSense+ w/4Fire SFI 17.1 Fire Sys•Weld Forged Vitesse Rear 17x10 Beadlocks-Front 18x6•Unlocked TCM
2023_ZL1-AUTO is online now   Reply With Quote
Old 09-08-2023, 11:29 AM   #17
Wuiquen
Wuiquen's Avatar
So, I did all this and more on my ZL1: My major FBO starts here:
https://www.camaro6.com/forums/showt...=611982&page=5
But my entire journey starts here: https://www.camaro6.com/forums/showthread.php?t=611982
When I bought my headers, I research a lot and I personally felt the CSP Headers manufactured by Stainless Works had the best and easiest install as far as clearance and how well they fit etc. I did this myself with no helper. Also, what size long tubes are you considering 1 7/8" or 2" or what? I went 2", but I feel since I was only doing Full bolt on mods, maybe I should of went with 1 7/8". But smarter people on this forum can chime in as I'm no where nearly as smart as most these guys!
I did mine in one day and before I started anything I watched this video multiple times (like 10) and it was spot on for my ! SOCAL.M6.ZLE makes all good points. I did mine owe header install because I was also do a ton more FBO mods. Thus, I just decided to roll up my sleeves and go for it! I made a lot of mistakes along the way that I shared in my thread. So learn from that and you might be able to get by with making few or none ! GOOG LUCK and remember don't over tighten the exhaust flange bolts where the headers connect to the exhaust and remember to follow the torque specs !!!!
Thank you this video helps a lot. I will review your threads and let you know if I have any questions. Every time I learn something new when asking about the headers for this car lol
Old 09-08-2023, 05:37 PM   #18
AZIROC
Drives: '86 IROC-Z '18 ZL1
I installed my complete exhuast in a weekend. But I also had a lift. I could have easily done it in 1 day but the 1st day I didn't start till around noon'ish and stopped around 6. The following day was just finishing the piping and buttoning everything back up. There is a few solid YouTube videos but I think I followed a thread made on here on how to do it. I've installed headers on 3rd and 4th gen camaros and they were a pain, on my zl1 it was WAY easier. Once the oem exhaust was off abd the headers off, the headers literally dropped out. The driver side header was simple to install from the bottom. The psg side I had to remove the head shield and dip stick but it went right in.
As far as cost. I got my kooks headers and borla exhaust for like 2k (kooks has a sale on top of a sale and I saved atleast half). The shop wanted me to buy the kooks and borla from them (3500) and 1k to install. I said f that and did it myself.
Old 09-08-2023, 06:20 PM   #19
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
What headers did you put on the 4th gens?
I installed Dynamax headers+off road Y into a magnaflow.
Then Texas Speed headers into their off road Y into a Borla.
Then American Racing headers into a catted Y into a Borla.
4th gens NEVER gave me the issues that I have been hearing exist with these 6th gens. I considered those 4th gen installs on jackstands easy
Are the ZL1s easier than the SS/LT1 to install headers?
KingLT1 and 2023_ZL1-AUTO thanks for the info I appreciate
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60'
Dynamical is offline   Reply With Quote
Old 09-09-2023, 05:26 PM   #20
AZIROC
Speed engineering mostly and a few pace setters (I think they went out of business a while ago) were the common choice for beaders back then. Exhaust was magnaflows or borlas mostly. Those installs were harder. The only added step to 6th gens is thst giant brace thing under the engine.
