#15 | |
![]() Drives: Camaro SS LE Join Date: Aug 2023
#16 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
The MAIN benefit of the AP Racing set up is that is is designed for VERY heavy track use and provides more consistent braking performance. ZL1 1LE components especially the brake piston seals fare BADLY in consistent hi temp use. Discolored calipers are just one of the effects you can visually see. I track 2-3 times a month so this is more of a benefit to me than others I am sure. The AP Racing set up uses 1 inch thick brake pads that not only last longer but they also dissipate heat better. Essex the parent company is the main supplier for both F1 cars and NASCAR applications. For casual tack use the Zl1 1LE set up performs well but pushed to the limit and their durability is SUSPECT. Another benefit is that the AP Racing set up saves about 20 pounds of weight over the nose of the car compared to stock Zl1 set up. The VAST majority of the wear and tear on a brake system occurrs on the FRONT of the vehicle. Your question about the effect of SQUARE set ups on wheels and tires I addressed before but basically it will eliminate understeer AND oversteer tendancys whick hopefully results in better tire contact on the rear and front of the car as you are transitioning thru the corners.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
