Old 09-07-2023, 10:15 PM   #15
asthmamax11
asthmamax11's Avatar
So we ended up removing the SMG pump, reinstalled the LT4 along with adding a DSX Aux pump. The car now has plenty of low side.
LT4 intank AND the Aux system ?
That wasn't overkill ?
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 09-08-2023, 09:40 AM   #16
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
LT4 in tank and JMS was installed before heads/cam/3-4 psi more boost and not enough. He originally didn't want to tap the tank so the lt4 was replaced with the SMG pump. Imo the SMG pump isn't any better than a LT4 with JMS. So he put the LT4 back in and installed the DSX. This setup is good for 1000whp on E60 if he decides to go that far.
Old 09-09-2023, 08:23 AM   #17
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
P2635- Fuel Pump 1 flow insufficient.
You can actually disable this code. It's usually required to be disabled with the DSX aux kit. You can do some tweaking of the stock fuel pump to reduce the chances of the code with the DSX, but it makes no sense that the drop in pump would trigger the code since it is the only source of the fuel pressure.
Old 09-09-2023, 08:40 AM   #18
KingLT1
KingLT1's Avatar
Yeah, after some further research I found that it was a nuisance code that usually only presents itself with aux kits. I did disable it and had it working with the JMS but it still would barely keep up when the temps dropped into the lower 70's.
Old 09-09-2023, 08:44 AM   #19
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Bummer, hopefully someone will have a viable plug and play drop in solution soon.
Old 09-09-2023, 10:06 AM   #20
KingLT1
KingLT1's Avatar
Hoping Katech's pump answers that call!!
Old 09-09-2023, 04:09 PM   #21
asthmamax11
Good info King
Thanks for follow ups
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
