Old 08-07-2023, 03:19 PM   #15
757Fixer
757Fixer's Avatar
Drives: 2022 1SS 1LE M6
Yeah, I'll be buying the BK063 lock out kit and the upper and lower trailing arms.
What about the diff lockout, is there any additional advantage to installing it?
2022 1SS 1LE M6 ordered 31 Jan 22
Picked up 20 Aug 22
757Fixer is offline   Reply With Quote
Old 08-08-2023, 08:39 AM   #16
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Originally Posted by cdrptrks View Post
.... It does increase vibration/harshness somewhat depending on the road surface, especially over bumps but the increase is not bad enough to prevent me from driving through a bunch of different states on trips....
Come to Pennsylvania, where our potholes and shit road maintenance will bend your forged wheels, pop your $400 tires, and compress your vertebrae like no one's business.
'18 1SS 1LE Black, PDR
Old 08-08-2023, 09:37 AM   #17
cdrptrks
cdrptrks's Avatar
I did about 10 hours of driving through Pennsylvania earlier this year visiting a few places on my way to Watkins Glen and then heading to PittRace after. I also drove through Pennsylvania for about 4 hours on different roads back in 2021 (before I had the BMR Rear lockout). Thankfully my wheels, tires and spine survived unscathed both times!
There were a few places in the Chicago area where the roads were terrible. I was pleasantly surprised to make it through there without any wheel/tire damage!
Old 08-08-2023, 10:01 AM   #18
Shawnqa800720
Shawnqa800720's Avatar
Drives: 2018 1SS
Don't forget your alignment.
Improper rear toe will make the car feel squirrelly.
This right here is the most likely culprit. Super wide, super grippy rear tires under hard acceleration can get very wiggly when the toe is out. And make sure your alignment shop knows what they are doing. I used to take my cars to the local XX cheap national tire discount retailer. With the Camaro, they never got the alignment right. My local Chevy dealer, and now my race shop are the only ones who could nail the alignment. What is "in spec" and "tight tolerances" for most cars will make your Camaro wiggly.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
Shawnqa800720 is offline   Reply With Quote
Old 08-08-2023, 12:10 PM   #19
Boost Creep
Drives: '18 1SS 1LE
lol
There are actually good roads to be had in rural PA, once you get near Philadelphia and it's surrounding counties it's a different story.
Old 08-08-2023, 12:39 PM   #20
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i live in california and all of our extra tax money from gas is suppose to go to the roads well let me tell you its 100% not going to fixing our roads lol im glad i have a truck now thats lifted with 34"s so i dont have to worry much about potholes and shit anymore
kropscamaro16 is online now   Reply With Quote
Old 08-11-2023, 01:36 AM   #21
funked1
funked1's Avatar
Drives: '23 Hyundai Kona N, '24 VW GTI
Originally Posted by JamesNoBrakes View Post
I specifically do not use sport/tour mode when doing AutoX (like today) because the progressive throttle (it's regressive actually, but not a huge distinction) puts down power way too fast to hook up in tight turns. The linear throttle of track though is perfect for not breaking loose too easily. They made touring/sport like they did to increase drivability and make it put down power faster, say for going from 1st to 4th with skip shift. It's also easier on the foot obviously by not having to push so far.
I drive exclusively in Track because of this. That way when I get to the Ax/track I have the same throttle response I get driving the car daily.
funked1 is offline   Reply With Quote
Old 08-11-2023, 01:39 AM   #22
funked1
funked1's Avatar
Originally Posted by 757Fixer View Post
I haven't checked alignment on my car yet but when I do I will ask for the Track alignment and give a copy of the specs to the shop doing it.
I would recommend doing it at a dealer that knows to replace the one-time-use alignment bolts. Or buy the bolts and make sure your alignment shop replaces them. Had my car aligned three times before I figured out why it kept going out of spec.
Old 08-11-2023, 01:10 PM   #23
6spdhyperblue
Drives: 2SS 1LE
If you ever get hptuners you can copy the sport(track) pedal map to normal(tour&sport) so they’re all the same
Old 08-11-2023, 01:21 PM   #24
bootss
Drives: 2021 ZL1 1LE with PDR
My car toe was out on one side in the rear. Made the whole car suck until I got it fixed.
bootss is offline   Reply With Quote
Old 08-11-2023, 06:30 PM   #25
757Fixer
757Fixer's Avatar
Very good to know, thanks!
Picked up 20 Aug 22
