Old 07-29-2023, 08:20 PM   #15
Sillysspeed
Drives: 22 LT1
You probably already know but the lt2 intake does NOT clear the lt4 hpfp assuming you have that. I went back to lt1 intake when I went Procharged
Sillysspeed is offline   Reply With Quote
Old 07-30-2023, 10:21 AM   #16
Dennis 2ss
Dennis 2ss's Avatar
Drives: Camaro 2SS 2017
I think that's an easy fix to just modify it to fit. At least from what i've heard. You have meth on yours?
2SS A8 D1X Stage 2, 3.7 pulley, Kooks LT 2″, Borla XPIPE/ GPI drop ins,Caddy Racing Lifters, ATI Damper, LPE GT35 Cam 42%, LPE Big Bore, FIC 30% Injectors, Fore Twin intank pumps, Flexfuel, MM wild catchcan.
865 WHP 743 LB FT
2Forge 19" wheels daily, Forgestar D5 17" for track
Dennis 2ss is offline   Reply With Quote
Old 07-30-2023, 10:24 AM   #17
Dennis 2ss
Dennis 2ss's Avatar
Originally Posted by cjperformance View Post
Oh, so now im going to have to mod to INCREASE my IATs?
Jk.... they're high enough.
I dont even want to know what it'd be on these 100+ degree days @ 50%+ humidity after a 1/4 mile pull. Its about 130 degrees peak when its 80 degrees ambient.
Im kidding about all that though.
However, im curious about the benefits of IATs on a PD vs centri. I've read that IATs are meaningless on a PD below a certain point. Ill just summarize to say that whatever IAT temp puts you below "knock thresholds" (hand wave)... because cooling down the air charge after the rotors CAN'T add any additional air MASS to the charge because of the nature of a positive displacement pump. A set VOLUME of air will pass the rotors depending on the physical characteristics of the PD. Whatever you do, that quantity of air will never change regardless of what you do to heat or cool it.
Only thing super low IATs could do in PD is decrease boost pressure by cooling, thus shrinking the air VOLUME (not to be confused with air MASS) after it has passed the rotors. In same way, decreasing the boost in this way ALSO has no effect because its always going to be the same air *mass* aka same quantity of air regardless of what you do to it after it has passed the rotors.
Now on a centri, not sure that holds up. Cooling the air charge, thus making it denser, supposedly has continued benefits on a centri the lower you go because it is not a positive displacement pump. Densifying (by cooling) the air after it passes a centri supercharger will allow higher air mass to enter the cylinder.
This is just what I've heard/read, not necessarily saying any of that is hard fact. Plus typing this out on my tablet, so hopefully that was all coherent.
To summarize, my question is... on a PD, if your IATs are already below the threshold where you need to pull timing, whats the benefit of going even lower on IATs, because once you pass the rotors, the quantity of air that enters the cylinders is the same regardless of temp.
AND does this work differently on a centri (and turbo too)?
Sorry, not trying to hijack thread, but the original question was about meth for cooling on a centri, and im unclear about whether there would still be a benefit for OP to add meth for cooling which occurs AFTER the air compression occurs for a centri.
Great questions. Maybe i have to test going meth anyway
Also thanks for all the answers. I will talk to my tuner soon.
865 WHP 743 LB FT
Old 07-31-2023, 11:15 PM   #18
Sillysspeed
Drives: 22 LT1
You have to run spacers with it. No meth here. Just stock boost 6-7psi and e50. Trans tune and ported lt1 intake in my future
Old 08-01-2023, 07:00 AM   #19
adamjwilson
Drives: 2022 Camaro 2SS A10
Pros:
1. Great for cooling (do not use of HP gains)
2. Washes the valves and keeps them clean
Cons:
1. Meth pump replacement every 2 years or so. Fairly easy on a Gen6- drop the passenger front wheel, and the pump is located in the wheel well for fairly easy access.
2. Filling up that bottle under the hood... lol
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
