#15 |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
A10 vs Manual
Ok so from a performance standpoint on ANY track situation whether it be a road course, an autox course or a drags, THEN the A10 is the BEST CHOICE. The only reason to go to a manual really is because someone just LOVES the idea of shifting.
The A10 is not as good as the dual clutch autos of the Porsches for example in terms of manually shifting the car with the paddles. It DOES NOT immediately respond to a paddle shift because there is a slight delay before the selected gear is engaged (when paddle shifting). HOWEVER, in AUTOMATIC mode I have found the downshifts and upshifts to be as crisp if not crisper than any other tranny including the porsches, lambos, audis etc.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#16 |
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
[QUOTE=sr71bb;11342592]Ok so from a performance standpoint on ANY track situation whether it be a road course, an autox course or a drags, THEN the A10 is the BEST CHOICE. The only reason to go to a manual really is because someone just LOVES the idea of shifting.
[/pop QUOTE] This. I think it does in the end come down to preference. I love the idea of being faster, but I also love the idea of that coming from driver mod. Not electronics and solenoids. I know I can be faster in an A10. But it’s important to me to keep the driver mod going, and narrowing that gap. I already feel like rev matching is cheating, lol. Plus I do think a well executed heal and toe downshift is worth a 1000 lever pulls. Like I earned that shift. So the next goal, unattainable as it might be, is to lessen my own gap to an A10. For me It’s the journey. |
#17 | |
![]() Drives: 6th Gen LT1 Join Date: Jun 2023
That or the pads go to the BCU and then the TCU/ECU? That might add some delay, but I don't know if it would be noticeable. Has anyone cracked this code yet? |
#18 |
![]() Drives: 1LE Join Date: Jul 2023
We have an A10 and M6 in the exact same spec. My opinion is that the A10 is faster around the track. Especially off the corner.
You will find me in the M6, because I enjoy it more and nobody is framing my lap times anyway. Haven't had any major A10 trans issues to date, but stay right on top of fluid maint.
Waiting on Willow Springs
#19 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Does the A10 give you a good amount of engine braking coming into the turns? Hard to tell in the above video. I'm wondering if the A10 cars may be a bit harder on the brakes.
#20 |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
That would depend if or how you are using the shifters? it would be like using the manual coming into the corners
#21 | |
Typically even in the slowest of corners engine speeds are kept in the 4500-5000 RPM range. The A10 does an excellent job of giving you the lowest gear that is most desirable for the speed you are going. Mine is programmed to shift UP at 6500 RPMs and it does that very consistently. This is BY FAR the best TRANNY I have had in ANY car that I have driven. This tranny originally co-developed by GM and FORD and was originally put in FORD TRUCKS. Because of THAT, it is a pretty stout piece just stock out of the box.
#22 | |
Give speed a chance
