Old 07-20-2023, 09:43 AM   #15
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Congrats on the win!
Old 07-20-2023, 11:08 AM   #16
jlaudio11
jlaudio11's Avatar
Drives: Chevy Camaro
Originally Posted by cjperformance View Post
What compression ratio are you running? On SBE, and E70+ @ 11.5 psi Im running 22 degrees at full boost.
Depending on your CR and the fact you have forged BE, I would think you should be in the low 20s AT MINIMUM for that boost level, maybe even high 20s if youve dropped your CR from stock... but it depends on many factors. I can only speak to my own experience. Please dont blow up anything because of what *I* say
Pretty sure laynlo is running more timing than i am.
Some research in engine characteristics shows that with all other things being equal an increase in stroke generally takes less ignition timing, with the piston spending more time at tdc and bdc. Maybe it just doesnt need as much timing in it. Going to keep researching, testing and trying but thought it was good food for thought to share.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 07-20-2023, 10:00 PM   #17
cjperformance
cjperformance's Avatar
Yeah, didnt realize it was a stroker. Thats exactly why no one should listen to me
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 07-21-2023, 09:02 AM   #18
KingLT1
KingLT1's Avatar
I bet that combo would run NA stock timing @ 6psi. At 12 psi it would likely be plenty safe on 19 degrees. 20 psi I could see 16-17 degrees. Reading the timing mark on the spark plug ground strap will tell you for sure.
Old 07-21-2023, 10:05 AM   #19
jlaudio11
jlaudio11's Avatar
King I appreciate your input!
So this is why I’m a little cautious and just trying to figure it all out gradually. I already have kr showing up at 17 degrees of timing. There are multiple things that could be contributing to it. For example I believe I have my commanded shift time too low for my 1-2 shift. There is a lot of kr right after it. I also started this pass with 109 iat and finished around 130. It was very hot with a lot of idling up to staging and waiting to run. My wideband is also suspect as it has been reading leaner than my narrow band factory O2’s, maybe I’m richer than I think I am. A new one should be here this weekend to try out. I guess what I’m sharing is that this is all just apart of the process of figuring it all out.
'20 Camaro LT1
Old 07-24-2023, 06:55 AM   #20
cjperformance
Its easy to get false knock. Found a clamp on my system that was touching the strut tower that i think was contributing to false knock under WOT.
Also have one of those metal spark plug boot protectors that may be rattling on the exhaust manifold heat shield...
Point being, KR may not always be real knock.... with a twin turbo, i could imagine theres LOADS of ways false knock could be introduced with all the new plumbing.
Old 07-24-2023, 08:46 AM   #21
jlaudio11
jlaudio11's Avatar
I don't disagree with you at all. Just saying why I'm being cautious creeping up on the whole deal.
'20 Camaro LT1
Old 07-26-2023, 06:58 PM   #22
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
Awesome nice win .
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
Old 08-01-2023, 10:45 PM   #23
jlaudio11
jlaudio11's Avatar
Thank you all for the congratulations. Here is a video I made from two weeks ago where we both won and then one from this past weekend. Lost first rd but did manage to go a new pb on the surface.
https://youtu.be/7i-eOCrjGjc
https://youtu.be/MhNMcdXjG7A
'20 Camaro LT1
Old 08-07-2023, 10:33 PM   #24
RedsRevenge48
Never satisfied :(
Drives: 73 Nova (project))
A little late to the party here, but congrats! That turbo setup is killer.
Those are some fast cars you beat! Also, those bronze wheels are SICK.
RedsRevenge48 is offline   Reply With Quote
Old 08-12-2023, 03:51 PM   #25
BDPhoto519
BDPhoto519's Avatar
Congrats man... Awesome job!
Not alot of NoPrep talk on these boards for the 6th gen it seems. What tire/pressure combo are you running. Any setup tips?
I was running the 17" ET R combo for awhile but switched to the DBR's now... On horrible surfaces or bad roads and water only passes I have tried some weight at the back wall of the trunk with decent results. But I am NA still so i like to avoid the extra weight when possible.
Thanks!
2018 Camaro 2SS A8 Redline Edition
BDPhoto519 is offline   Reply With Quote
Old 08-12-2023, 09:05 PM   #26
jlaudio11
jlaudio11's Avatar
Thanks!
Thank you!
I run the Hoosier quick time pro, most of the events I run require a dot tire. They’re also mostly really bad surfaces where I need as much as I can get. I would like to try a dbr at some point though. Currently they’re set at 15lbs and I actually don’t have any weight in the back. I launch the car like it’s on motor, revving to 1400rpm and then smacking it. It 60’s like crap (1.9X)because it falls on its face till boost comes in but then it takes off like a freight train. I’m fortunate that this event most people can’t 60 very hard anyway because the surface is so bad. The car would go 1.6-1.7 on the street on motor before turbos. Back then I would run up to 2 70lb bags of sand in the trunk. Anymore and I felt like it squatted the rear end too much causing too much negative camber and poor contact patch.
'20 Camaro LT1
