#15 |
![]() Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
About 7000 a set. With 8-10 track days on them.
One note, these F1s still grip fantastic after the thread is gone in the dry. Once wear bars were no longer visible, I still got 3 solid track days out of mine. |
#16 | |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
Could definitely get a track day or two out of them still, but I drive on street 90% of the time and must be up to date on inspection. The upside, SC3s are less expensive than many other options, and are tremendous performers! |
#17 |
![]() ![]() Drives: 2021 2SS 1LE Join Date: Aug 2020
I'm at 16 track days and 3mm still remaining on my original SC3s. They wear quite well.
I'm starting to wonder though if the rubber is getting a little harder and grip is going down a bit. Then again, I can still hit pretty high momentary G numbers like 1.35 from time to time. |
#18 | ||
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
Just shy of 13k each on two sets of Goodyears, switched to Continental Extreme contact sports and have a little over 36k miles, still some tread. Mounted up Continental DWS's on second set of wheels for the "off season", so we'll see on those.
Street only, weekend cruiser. Rear tires went bald and fronts got cupped. The Goodyears really grip, and throw everything on the road at your rear quarters. They do get hard with age, so did the Conti extremes. I thought driving in the cold (above freezing) accelerated the hardening some. The Goodyears still have rubber left even after the tread is gone, there are witness holes near the outer edge to measure.
'18 1SS 1LE Black, PDR
#20 |
![]() Drives: 2019 2SS 1LE Join Date: Mar 2020
I'd say 10k miles to be certain, some time ago I had tires with almost 15k miles, went over a MINISCULE puddle while taking a u-turn at around 25, spun the car, got into the median and almost crash a post that would certainly have totaled the car.
Current: 2019 2SS 1LE aka "Blanc"
Previous: 2017 2LT aka "Noire" Mods: Chevrolet Performance Suspension || K&N Cold Air Intake || Borla ATAK Mufflers + Catback system || MRR 650 ZL1 replicas with squared 285/30 Michelin Pilot Sport 4S || ZZP 4 piston brake kit + braided brake lines || BMR everything (Solid/Lockout cradle bushing are a MUST in Camaros) |
#21 |
![]() Drives: 2017 Chevy Camaro 1LE & 2023 1LE Join Date: Apr 2021
10K miles is about the ceiling for mixed street/track driving. That’s when I had to swap them out! Probably should have done it a little earlier actually. JM
#22 |
![]() Drives: 2018 SS 1LE Join Date: Sep 2018
no track.. just the occasional weekend cruise.. just started daily driving it though
13k on them with some meat left.. might be able to go another 2k any all weather tire recommendations? need to get some before winter.. those 305's seem to be hard to find online
2018 SS 1LE
#23 |
Continentals.
#24 |
![]() Drives: 2019 2SS/1LE Shadow Grey Join Date: Nov 2015
I have p-zeros and I have put 17k on them with plenty of life left....2 years 8500 miles a year
#25 | |
![]() Drives: 2018 1SS 1LE Join Date: Dec 2012
#26 |
Tri-County Camaro SWFL
Pretty sure my wife got about 10/11k out of the rears. Fronts are a little under 50% tread. Zero track but she does like to hammer it when the light goes green.
#27 | |
Less tram lining and rain isn't life threatening. I've been on the DWS's for about 8k miles, these are a little looser but grip surprisingly good for an all season.
#28 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
The ECS02's I considered those but I didn't like the previous ECS that I ran on the 1LE so I stuck with the SC3 that I knew I was happy with and they were hundreds less than the ECS02.
